Archived: the OG noob question thread! šŸ˜€
Yep, @Venom121212 is correct. The battery cutoffs are fine too.
When you do motor and sensor detection/calibration, should the motor be hooked up to the pulley already? I’ve seen conflicting answers
I don’t know what there useing now but back then I believe they were rebranding diyeboard batteries which I believe Are Samsung 22p. I could be wrong tho.
@ADrum707 there is a whole thread on what to set cutoffs at
ESC Battery cutoff settings
@deckoz @Sender Do you know if these sk8 motors are 80mm or 89mm long?
Hobbyking definitely says 80.7mm
I remember 89? But it has been a minute
Just came back from a test ride… I definitely dig the new settings. Not sure what factor or what combination of factors led to it, but the motors response feels so much better, brakes are better as well. Can’t thank you all enough for your help! @MysticalDork @Flasher @mmaner @b264 @Sn4Pz @Venom121212 sorry if I forgot anyone!
Hey so I’m just about ready to build a battery but i’m not sure of ALL
the parts necessary heres what I think i need please tell me if i’m wrong
50 40t cells
10 m of nickel just to be safe
charge only bms
charge port
fish paper
5 feet of 10 gauge wire
spot welder
Multimeter
Fuse for charge port
Balance wire if your BMS wires arent long enough
Heat shrink for whole battery and different wire gauges
Solder
Soldering iron
Flux
Kapton tape
Filament tape
These are a few things that I use that arent on your list!
thanks exactly what i was looking for putting a 10s5p on my meepo v3 :upside_down_face: right now looking at finishing up end of december
Would also suggest that you read as much of this thread as you can :+1:
thanks great resource i have been reading just couldnt find a parts list i have a pretty good concept of cell layout
I have a dual cheepo ESC and new model remote from dickyho…when I max out the throttle it will vary the speed (bench testing), is there any way to determine if it’s the remote throttle or the ESV itself?
I’m not excessively worried about it because it’s just gonna be used by friends who won’t pass 10mph anyway (yes I’ll make them wear a helmet), but if it’s just a new remote then I’ll pick one up from dicky when I get more goodies from him
What’s the big difference between Uart remote connection and PPM?
Different security protocol? One is more reliable than the other?
If there is already a topic on this, please link me to it, I didn’t find anything on this subject.
@stan Deckoz pointed out failsafes
https://forum.esk8.news/t/issue-with-unity-and-metr-at-module-while-logging-data/10021/80?u=flasher
PPM (or PWM) uses a single wire and sends a square wave with varying pulse width. The ESC senses the pulse width of the square wave and adjusts the motor speed accordingly.
The PPM communication uses a single data wire and the flow of information is only one way, from the controllers reciever to the ESC.
Different receivers might give out a slightly different pulsewidth when idle and that is why there is the option to adjust the deadband and the midway point of the signal.
UART uses digital serial communication (ones and zeros) and two data lines. The use of both RX and TX lines between the receiver and the ESC means that information can be sent back from the ESC to the remote. In practice this means that you can show stuff such as the current speed and power draw on the remote.
Unfortunately the fail-safes he’s talking about don’t even apply to uart control method, so it’s kinda like complaining your submarine doesn’t have wheels. The two systems are so different there’s no Apple to Apple comparison.
The fail-safes he’s talking about already exist in different forms with modern radios, or aren’t applicable because the tech being used isn’t RC hobby tech from the 80s.
@deckoz nerd fight me bro.
Sure, but in context you made generalized statements about ā€˜uart remotes’ that don’t even apply to the tech.
The 3 failsafes you mention only apply to analog and digital RC hobby tech. Hobby receivers have ā€œ2-3 channelsā€ that output a pwm signal on each. A default output for each channel in case of loss of connection has zero bearing on uart method of control.
For example, on OSRR we’re using advanced industrial series 802.15.4 radios. These don’t have traditional ā€œchannelsā€ and don’t use PWM because they can send much more complex formats of data, potentially even at lower latency, at a much higher rate than an RC hobby remote.
The radio modules alone, not even entire receiver/remote device, have their own dedicated CPU that handles it’s own fail-safes at a firmware/hardware level. This all happens automatically even below the level in which I’m programming the OSRR remote code, but is fully configurable during setup. Multiple checksums at play, 115-250k baud rate comms so it’s near real-time.
The radios are paired & encrypted, have PAN IDs they operate on and within that addresses/broadcast modes, so it never needs to search.
There are multiple redundancies, fail-safes, and safety/encryption features that RC hobby remotes simple don’t/can’t support.
8’s are 89 and 3’s are 86. The site just gives you the can size not the overall.
