Looking to setup a new board with Apex Air trucks , but finding limited options for mounts or drives…
So far found three, but I’m sure there are others. Please help me find some more options, I’m ok with either belt or gear drives, but nothing too expensive. So that excludes anything Trampa.
Gear Drives:
https://mooneskate.com/collections/all-terrain-moon-drive-kit/products/base-unit-at-moon-drive
?? FatBoy Gear Drive – 3DServisas
Motor Mount:
Hello everyone
A few days ago I described motor mounts for RKP , TKP and DKP trucks.
In this topic I offer motor mounts for trucks:
MBS Matrix 1 (older type)
MBS Matrix 2
MBS ATS12
Apex Air
Trampa ATB Spring
Trampa ATB Precision Spring
Trampa MINI Spring
[238879048_4216076248518426_2184136545925107203_n]
Motor mounts v7.4 and v7.8 are designed for gear ratios 16/72
16 is the number of teeth of the motor pulley, the number of teeth can be smaller
72 is the number of teeth of the hub pulle…
I think you’ve named the three things that are available.
I’m not sure if Kevin intends to make his belt drives compatible
@IDEA makes real good motor mounts for them if you’re interested in belts.
Edit: just saw you listed them. Hahaha
moon:
I’ve got some batch 4 drives that I can sell for £200 exc postage
How many you have left?
moon:
Also have some motor mounts but they’ve not been tested.
Motor Mounts for Apex Air only?
moon
October 2, 2021, 8:15pm
6
Tamatoa:
Theres a few available…I should make a sale thread. Got a couple used drives kicking about too
MBS, Boardnamics, Trampa CNC, Luna etc.
You use the same clamps than the gear drives?
moon:
etc
Hyper? Kinda fucked myself with options
moon
October 2, 2021, 9:34pm
11
yes hyper should work too
