Yeah It’s just about getting what I have sitting here to work.
Actually since this 15S life pack is so close to a 13S one could they be directly paralleled? I forget what the rational with combining dissimilar packs is. If not I have a CC/CV that I can throw in.
If one has a lower internal resistance, it will deliver more amps than the other, and then when they have a resting moment, the high resistance pack will push a lot of amps into the now lower voltage pack. This essentially leads to extra cycling, potentially at too high c-rates.
People will advise you not to.
But if you never dis/charge them beyond either packs’ limits and in use draw A good bit less Amps than they could deliver, you will be fine in practice.
If you are ok with them potentially breaking sooner, and want to experiment a bit, go for it. But be sure to understand what you are doing first.
Still haven’t convinced myself that I should get a bunch of those A123 and make a pack with them and save a little bit of money or just empty the wallet on P42’s.
I know @malJohann used LiFePo4 for a while, but switched over to LiPo. From a AT/OffRoad board perspective, just not sure if its going to be a bummer or not lol
Weight is obviously a big one to consider compared to their power output and whatnot, but to me atleast, the main thing is how long the a123 cells will last, and their nice discharge they offer throughout the ride.
Although, they weight much more and have lower voltage than that of the other competition
Graphene lipos seem to have long cycle lives as well, 600+ in some cases,
while keeping the juicy power.
Longer lasting; lifepo4
More performance; li-ion, lipo
You obviously know much more than me on this, that is just the reasoning I laid out for myself when choosing
I use a 10S Li-Ion charger from Baja with an adjustable pot on the inside. For a 10S LiFePO4 I charge to 36.5V (0.5V more than “full”, only do this on LiFePO4). Full charge is 3.6V per cell.
I run mine as 20S and charge them as 10S for the moment.
Other way around chief, and LiFePO4 rules for me.
What do you classify as performance? LiFePO4 has great, stable performance for 90% of the charge, just lower capacity and nominal voltage, so you have to compensate with more cells, which ultimately means more weight.
