Where can I find the Evolve hub mounting pattern dimensions?
Does someone have the hole pattern spacing and screw size for boardnamics precision clamps? Or cad file but not necessary, need the dimensions so I can cut some plate until they arrive
Bet @Boardnamics does
I read this thread and it’s like you guys are tag teaming to build the first Iron Man suit in a cave somewhere! ![]()
36mm BC Diameter. OD of the plate is 50mm
Does someone happen to have the hole mount pattern and footprint for the Hypertruck baseplate? I cannot seem to find it anywhere online. TIA
Thanks a lot ![]()
Thank you, very helpful!
Designing mudguards for TB motor mounts to use with my rubber wheels. Never done any 3d prints and I’m a beginner with 3d modelling. I have a friend helping. Any tips to make this design 3d friendly? The printer will be a Zortrax m200.
mudguard2.STL (42.1 KB)
Is the focus more on part strength, print ease friendliness, or material saving?
I swear I made some tb mudguards for someone here before. Probably not the same version they’re on now but I’m still gonna look back and see.
Edit Nope they were belt and motor covers.
These first two are the objective. I’m getting help by @SpeedDemon as well and he revised my drawing so I will first take a look at that, later in the day. It’s very clean and beautiful!
60T Pulley Revised.stl (2.4 MB)
Modified Bergmeister pulley. Captured nuts in the rear look much neater than having them out front, and ensure the pulley can actually be fucking disassembled without resorting to pliers and brute force.
Thickened up the pulley wall as well to reduce risk of failure. Print in ABS, 80% infill.
VS
Awesome, I was looking for this long time ago!
What is the length of screw?
Can’t remember off the top of my head, I want to say 35ish?
Do you happen to have a STL for a +5 degree riser for the matrix 2? Ive been using your -5 and its been great!
Thanks! Will this line up with the regular metal baseplate ok?
It definitely should. Lmk if it doesn’t for any reason and it’s an easy fix.
