3D files / CAD request thread
Thanks!
Can’t wait to see the process and results!!!
Did you recently watch a YouTube clip from “easy composites ltd”?
Not recently, but yeah, those guys gave me new incentive to finally try this out. I’m currently doing somewhat of a similar process to make forged CF/GF enclosures, so it’s not that big of a step up to rims. The only problem I see so far is the complex shape of the spokes being an absolut nightmare to demold, so I’m torn between a reusable mold and one-off molds.
I’m also considering designing my own hubs, as that way I can work in features that make molding and demolding easier.
I saw that video and ordered some chopped tow to play with too. I’d been waiting for the “results” video where they compare the strengths and found a link to it on their site: Comparing the Mechanical Properties of Forged Carbon Fibre - Easy Composites
Seems very promising
Shock pads for original Hearo Bro
SS-hmm.stl (278.5 KB)
Anyone have a Hearo Bro 96 model?
Anyone have a model of a Loaded Icarus deck?
Edit: it’s here random CAD Dump update 4/7/21
Hi. I was realy not clear to which tread shoud I shate it. So I hope it is ok. I designed it for better comfort in battery build.
Does anyone have cad file for the switch blade deck, I want to make a deck and have access to a cnc machine.
Do these fit MBS, Kaly, Lacroix and Tranpa?
They are patterned for the plastic baseplate of mbs matrix 2 trucks, 42 x 62 mm (old school to be specific) bolt pattern
OK, looking for 5 and 10 degree wedge and de-wedge risers for a Kaly pattern.
Is kaly old or new school pattern? I’d be happy to adjust the design to get it worked out.
If they’re the same as twampa, I believe these are the measurements
Does anyone else acount for the deck height change when wedging dewedging? I tend to see wedges that are mirrored front and back which raise the back of a mountain board.
I have current trampa risers. In any config you want. Will post some when back at my computer.
Yeah definitely. I try at least. Its hard to guess how much a certain angle will affect the ride height without just doing it and measuring tho.
I will check when I get home but I think the 4 holes are 8mm clearance and 2 are 41mm apart and 2 are 69.5mm apart
I have a fusion project that solves the math equation for you. I need front and back starting angle (usually they are both the same and around 30°), wedge and dewedge angles, truck Axel geometry (I have this for trampa infinity, and matrix 2).
I can make matrix 2 or trampa offset angle risers in any config in about 2 minutes.
