Looks like a JST GH 1.25mm 6pin connector.
I got mine Saturday. They appear to be high quality. I’m going to work on getting them installed this weekend.
So it sounds like this a 20-25A battery, 60A motor kind of controller?
some updates.
designed a new housing for the v6c. new size 48x77x30mm with fan.
added usb-c port.
14awg motor wires were replaced by 4mm smd nuts which is able to handle higher current.
added canbus connector.
fan? I dont know… more parts, more complications, more points of failure… passive design always wins out for reliability
Just use a bigger heatsink -> more surface area to cool passively. Plus I doubt that you would be running it at 1kW continuously
Which is why all cars have passive air cooling?
A fan would be nice if our enclosures had airflow. Most don’t though. Just adds extra space and cost.
aww, but car cooling can be quite unreliable…
but thats coming from someone who’s most expensive car ever was 1500€
edit: holy shit my esk8 was more expensive
This would put single stack enclosures out of the question with the fan, way too thick.
Ideally something 20mm or less would be good.
You could have enclosures with fan openings. Would have to put some sort of dust guard though
Brine guard LoL
v6c, ‘c’ means compact. if I use large heatsink, it confits with my design rule.
I did the test just to show its performance. as I know, even 500w maximum (not continuous) is good enough for normal dual drive skate boards.
if its the case, fan can be removed.
same answer, if you don’t need 1kw continuous output, fan can be removed.
What kind of wattage could this handle if I gave it a massive heatsink to dump heat into?
Hi @zhanzhan
What should I do if I want to connect the metr(UART) and PPM receiver at the same time?
updates.
I changed layout of the board and designed a new housing for it. with this new design, v6c can be mounted on what ever heatsink you like.
new size: 48x84x9.6mm
No, My concern is that no servo connectors like other VESCs are found.
I‘m not common with the phase wire connectors. Do you have a picture how the male side would look like, or as min how high they would stand up out of the case?
