Its a flipsky product
The 4.12s are literally unchanged vedder ones arenāt they? I find as long as its not DOA, it performs as a 4.12 vedder esc does
My understanding is that most peopleās complaints about flipsky is the QC
I canāt comment too in depth about component level stuff, since Iām not very knowledgeable about it, but from what others have shown on the forum I wouldnāt make a 1:1 comparison.
Also very few, if any, 4.xxs are floating around straight from Vedder himself. I would point a finger at the materials flipsky uses, as well as their QC like @BenjaminF said.
Granted flipsky likes to sell their products cheap, I expect them to cheap out when buying the components.
Yea 100% the QC is shitty, especially right now. For me at least, iāve had excellent luck running 4.12s on low amp simple builds (Like 20 battery ampsish), they pop up on UK ebay for literally as low as Ā£35 shipped taxed which is just ridiculously cheap, so I always pick them up for small side projects. But it kills me inside when I see a new builder fall hard into the trap of running them in 12S FOC on his main build.
The ZESC looks nice, hopefully the year of new ESCs keeps rolling
I was given 2 FlipSky 4.20 Plusās for testing before the commercial release. Both are still going strong. They are both on thane drives with 10s or 12s packs, high miles but not extremely fast. I have bought 3 others for builds and all 3 died within weeks.
I donāt know if that correlates to QC quality, but itās definitely not good.
@mmaner what was the failure mode?
I suspect it might have to do with the soldering. Iāve noticed their products have quite a few cold joints, itās a side effect of the heavy copper they use (heavy copper is GOOD). I suggested to their CS department that if they are not already using a trapezoidal reflow profile, they should switch to one.
There seems to be better QC roll on the single units. (Less copper to heat up?)
Thatās exactly what Iām doing now, original tb vesc 4.1 with 1000+ miles on it probably, like 4 years old, still doin its thing. But itās only been pushing 15 battery amps the whole time.
My friend had a tb vesc that died first time FOCing.
Flipsky not the only ones with unlucky QC xD.
sweet, I just build a 20a mono belt thane board as well. (build thread soon) Whats the top speed you get? I get 32 km/h when calculators say I should be getting 39km/h loaded. I chalked that up to the 20a max, but curious to what youāre getting
It was DRV related, you can see the damage with the naked eye. Iāll fish them out f whatever box they are in if you want it.
I had two TB 4.12s that I ran 40a batt max FOC on and they lasted the year I used them, until I decided to sell themā¦ and presumably are still working today
Everyone has QC issues, but there are definitely superior 4.xx variants
Itās a dog runner so never even tried to push it. It goes as fast as my 15lb dog can run.
Yea theyāre either bulletproof or they burn out quickly.
My fesc6 is now officially dead, only took it out for a test. Then a sputter. Now dead.
Here is the test video.
Test1: low rpm and 60a phase current. FETs_temp ends with 53C.
Test2: high rpm 1000w load. FETs_temp ends with 30C.
You should perform the openloop command when testing the capabilities of a vesc, I donāt understand it fully but I know itās what Vedder uses to show his designs off
For those who didnāt watch the video this is only 10s, not 12 or 13s
Also what happened at 2:07 in the video? That looks like it would be pretty awful to happen if someone were actually riding it
Is there a reason the duty cycle isnāt at 100/95% when pulling the full 60a, but is at max when doing the 30a pull?
Whatever it is, it appears mechanical. Almost like someone suddenly pulled a friction brake, but I donāt see a brake there
Iāve had a sort of similar lock up like that happen when mixing a Chinese ESC with hub motors from a different vendor
Also in the video you see the duty cycle slam to 0, looks like the vesc rebooted / reset itself?
The motor was over-temped, so magnets were going to demagnetization. This resulted lower torque and motor got stuck.
I use my foot to control the friction of the wheel. sometimes I cannot control well. put too much force on it.
