yes, it does have canbus, but the chip is not soldered. this single channel version is designed for updating electric scooter. So, canbus is not necessary. I will release a dual version later.
When you get around to making one with a canbus port or an outright dual Iâm interested in trying it. Either way, looks cool and itâs dope seeing folks make stuff like this.
Yes but it could demonstrate that the failures are caused by resistance value choice and not by the design, and an in-between value could work better.
Science
Since I didnt get a response from earlier question, could you please do a short demo(video) on the bench with 13S (really 12S would tickle most people enough).
Alternativly, send one sample out to someone with the equipment to bench test it properly?
If youâre looking to get a few into the wild, this would certainly help people make up thier mind.
Have I seen this ESC before? Maybe on the Vesc project forum?
Similiar design, but not the same, youâre probably thinking of the mini one that had helluvalot of caps, right;
im interested. send you a message on www.electric-skateboard.builders
Hi OleksiiF-
Level bumped here. Welcome!
Thanks, homeslice.
hot price
Hi! I just designed a simple case and mounted a 40mm fan on it. I will do the test again and record it later this week.
Obviously this one is much larger. One problem i notice is that you are only able to mount the heatsink on the top of the mos, which means that heat cannot transfer quickly. It must have some over temp problems (he rated 200A). Also, we know that shunt amplifiers saturate at 165A(if he doesnât modify the firmware), so how he got 200A rating?
Alright, who bought one?
i did. itâs for a low powered mono drive so iâm probably not the right person to stress test it.
Let someone stress test it with their money.
whats wrong with fesc 4.12âs for a low powered mono drive? :o
