Z.mote , new esk8 remote
Yes but slow shipping from China
I have 30 102560 ordered from China, should arrive in 4 weeks. I could sell them to same price as i bought them for once they arrive.
And yep my remotes just arrived and I will have to wait for the batteries…
I wonder if an appropriately sized LiPo could be reclaimed from those disposable vapes littering the streets.
I think they are usualy cylindrical ?
The one I got for my trigger Zmote is a flat/rectangular type (this one here).
Duct tape a portable power brick to it and ride off
/s
I meant the ones in the vapes
There are some flat ones I’ve found, and there are small cylinders that you can parallel in the same space.
If you have a old flipsky remote you could probably take that battery.
BTW, you will also need a 1.3mm hex driver to open the case. A lot of people may only have 1.5mm. The battery compartment can handle up to a 60x25x10mm battery. The catch is that the remote charges at 1A so unless you want to change a resistor on the PCB to reduce the charging current, most smaller cells won’t be able to handle the charge. And yeah I also looked to try to find a couple of appropriate cells I could parallel but couldn’t find the right size yet. I did find a cell from a Maytech remote but it won’t be able to handle that charge.
I got my last trigger Z-mote going.
So I have 8 now.
No issues so far.
20230522_221738_1
If anyone has an old evolve remote those use a 102050 LiPo
I did manage to parallel two cells from two of the Maytech double trigger remotes to get one of my Z.mote double triggers going. I was glad to throw those in the garbage and I am also looking forward to retiring my Hoyt Pucks.
I will ride with it tomorrow but in the meantime I can already tell that that the way the grip is styled with where the fingers go, and with the size of the brake trigger, my hand is apparently just slightly a bit too small to comfortably push the brake in all the way without having to stretch a bit and so it is easier for me to have my thumb a bit on the left edge of the brake trigger. It’s a small thing but I have suggested to Kamen that it might be nice to have some slightly different shaped brake triggers that people could print.
Are the duel trigger remotes available now or still testing?
I believe they are available. I got mine through a regular order.
Weirdly I only see links to the single trigger and thumb wheel.
Top link dead.
Just write to Kamen on Tindie. @b264 posted the link above.
I rode with the remote today and so far it’s freakin’ awesome. Based on my initial experience plus everyone else’s Z.mote experiences, I’m going to order another two of these double trigger ones.
