Sorry if I was not clear. Shredlights has the CS in the esk8 market in general. Lacroix has the best CS in the ESC market.
ftfy, but probably still not true when u have metr around
uh no, u should buy a board from them and see how the CS are. stormcore isnât a main selling product for them i assume.
That helps explain some of it with the reply times this past week. Two people I know personally had put in support tickets and never got a response, but that was a few months ago.
The only other think has been the solutions offered to problems. Obviously nothing against you as they are probably company policy, but it does somewhat contradict the statement that Lacroix is âthe final frontier of electric boarding technologyâ. I also do know it is hard to know if it was a factory defect or the customers fault with this stuff.
I mean all of this in the nicest way as I do appreciate what you do for the community.
I have a strong feeling that has to do with a glitch we noticed a few months back. It was causing support tickets sent through the website to not reach us. We have no idea why but it sucked. I can personally assure you that if a ticket is submitted, Charles will try to answer it. If a ticket goes without answer, thereâs only 2 possibilities.
- the ticket wasnât an actual question or problem to solve.
- it didnât reach support.
Alot this ![]()
I do my best to be up to standards
I havenât dealt with metr.
And Iâm saying that out of all the ESC manufacturers, Lacroix has the best CS. Iâm sure they have very good board CS too.
metr is so good that their stuff doesnât even break lol.
and they keep adding new, cool, useful features. shit, when i thought the development might slow down due to some bottleneck, then boom, metr came out with new features.
those guys are crazy
And Lacroix will help you no matter what youâre wearing, although i would expect my customers to stay snatched, so they have me there.
0,3A is too high current. Something is shorting. My guess is the driver for precharge fets. I have seen this IC broken before without hole in it. Check if it gets warm too touch in that case when you short the mom pins.
Another test⌠You can connect a motor and spin it fast by hand. That will generate a voltage on the esc side of the antispark circuitry. The voltage needs to be high enough for the DRV to start converting to 5V. See if you get the LEDs to blink. If they do, then precharge circuit is the issue.
Literally the best thing I have read since I have been in the forumâŚ
I didnât know shredlights was in the esc business
I donât like raining on parades but how many esc companies have you dealt with?
I donât really have the equipment to prove my theory, but I killed 2 spintends a stormcore and a flipsky 6.6+ eliminating all other problems.
On the second spintend I switched the sides. And it bricked that side. Therefore it was the motor. Joey z suggested the sensor was the problem, so I hooked up to the vesc tool minus the sensor and no problem was observed
The UBOX is a good option if youâre well versed in vesc troubleshooting and if you have plenty of time. I had 2 out of the 3 I ordered not have working sensors, but Spintend support jumped into my DMs and walked me through the solution.
Unity and xenith is good if you need something small, I prefer to buy them used so I know itâs not a QC dud.
Stormcore is the gold standard.
It might be 0.03a now u mention it. Cant remember but ill do those tests anyway.
I bridged the mom pins and went around feeling for any heat and i get a warm touch from the â220 T3â.
Am i fucked? Fixable?
Havenât tried spinning the motors yet.
@Blasto you might know
Itâs an inductor and it is in series with 5V. Some where 5V is shorted. Could be the 3V regulator. It looks damaged⌠does it get hot?..what is this in the corner?
Generally if something is big dead it gets more than a little warm to the touch, so thatâs not an immediate death sentence. As @Fatglottis said itâs an inductor, and Iâm also curious whatâs up with that other component with the mark on it. The mark looks like a solder blob
