[WTS] [US] CURRENTLY SOLD OUT - Fess Sells
Sold 51 - 74
# item cond price
51 set of 11T 12T and 14T Mod 2 (Moon Drive) Pinions (8mm shaft) mixed $40 $36 $32 shipped (US)
52 Drive Train, 3ds mini gear drive 1:2.8, Fatboy hangers, Abec 11 107 superfly used $400 $360 $325 $290 $260 $234 $210 $189 $170 $150 shipped (US)
53 Z.Mote Trigger with Torch option used (barely) $125 $110 shipped (US)
54 @Savage1 prototype boardnamics clamps for SRB HD axle new $100 $70 shipped (US)
55 Boardnamic M1-AT clamps for SRB HD axles new $34.99 $27 shipped (US)
56 @surfnacho InfinitySink Universal ESC Heatsink new $60 $45 $40 $36 $32 $29 $26 $24 shipped (US)
57 MBS F5 binding. Left foot. used $45 $40 shipped (US)
58 motor bolt 40mm to 30mm adapter used $20 shipped (US)
59 Freesk8 OSRR Receiver (Unobtanium) used $50 shipped (US)
61 Apex Air Trucks. Unobtanium! new $299 shipped (US)
60 MBS bushings used free + $5 $4 shipping (US) or add on to something
62 Freesk8 GPS module 1.25 used $20 shipped
63 Freesk8 Xenigochi + GPS 1.25 module used $90 $45 shipped
64 Pair of Little Focer ESCs hw v3.0 new $699 $629 shipped (US)
65 Focbox Unity #2 used $199 $180 $162 $146 $132 shipped (US)
65b Foxcbox Unity #3 used $199 $170 $150 $135 $122 shipped (US)
66 Stormcore 100D+ (Unobtanium) used $399 $359 $323 shipped (US)
67 Apex Jump Drives (Unobtanium!) new $499 $410 Shipped (US)
68 Pair of Torqueboards ESC + InfinitySink used $219 $197 $177 shipped (US)
69 XCELL™ APOLLO™ XT Wide wheels and tires. set of 4 used $339 $305 $274 shipped
71 Spintend 75/100 dual ESC new $230 $207 $186 $167 $150 shipped (US)
72 Kaly DS 18650/21700 Enclosure new $228 $149 $134 $120 $108 $97 $87 $78 $70 $63
$98.00 shipped (US)
73 Kaly Deck XL 2.0 pre 2021 used (good condition) $299 shipped (US)
74 12s4p molicel Duck battery, Enclosure and BMS used (barely) $169 + shipping
show me the sold stuff
#51 set of 11T 12T and 14T Mod 2 (Moon Drive)
2 pair 12T used.
2 pair 11T barely used.
2 pair 14T new.
8mm shafts
more pics
#52 Drive Train, 3ds mini gear drive 1:2.8, Fatboy hangers, Abec 11 107 superfly
3dservisas Mini gear drive (just did a service with new grease) 1:2.8 ratio
2x230 hangers FatBoy cnc
2x caliber 2 baseplate with riptide bushings and pivots (rear 44 and front 50)
4x Abec11 107mm superfly wheels
NOTE*: i overheated one of the motors with a heat gun trying to get a case screw to unloctite and dislodged a magnet. lame
so listing is for 1 motor.. and one.. borked motor. which maybe if you’re into ti you could reepoxy and fix.
1x6374 motors 220kv
more pics
#53 Z.Mote Trigger with Torch option
Z.Mote with torch option
Unfortunately this thing just didn’t fit my hand properly. (small hands) Otherwise I really liked it.
Kaman offered to print me som mod’d triggers to try to work it out. But I just don’t have time to take him up on it.
So.. rather than it sit around. it needs to go.
more pics
#54 @Savage1 prototype boardnamics clamps for SRB HD axle
These were produced in a small batch by @savage1 designed to help attach the boardnamic SRB clamp to the axle.
I never got around to trying that experiment as my boardnamic GD got sniped for a different purpose.
more pics
#55 Boardnamic M1-AT “clamps” for SRB HD axles
these are stock from boardnamics.
requires a jam nut to “clamp”. but see #54 above to add actual clamping.
more pics
#56 @surfnacho InfinitySink Universal ESC Heatsink
more pics
#57 MBS F5 binding. Left foot.
I knew i had another one of these somewhere. found it today searching for pinions. :grin:
more pics
#58 motor bolt 40mm to 30mm adapter
bolts to a motor with 40mm bolt pattern allowing it to fit in motor mounts with a 30mm bolt patten.
more pics
#59 Freesk8 OSRR Receiver (Unobtanium)
I knew i had one spare somewhere. Also found this digging through stuff looking for pinions. yay.
Does not include GPS or GPS cable.
Includes partial cable connector on receiver end only. see “more pics”
more pics
#61 Apex Air Trucks. Unobtanium!
more pics
#60 MBS bushings
just need shipping to get these to whomever might want 'em.
can add em on free to anything else too.
more pics
#62 Freesk8 GPS module 1.25
more pics
note this is v1.25 of the gps module.
gps module, cable, and top case only.
#63 Freesk8 Xenigochi + GPS 1.25 module
note this has version 1.25 of the gps module.
and v1.5 of the xenigotchi, tho it has a larger gps connector than other v1.5 i’ve seen.
xenigotchi, gps, cable, case and bolts included
more pics
#64 Pair of Little Focer ESCs hw v3.0
more pics
#65 Focbox Unity #2
xt90 power and 4mm bullets. power button included.
more pics
#65b Focbox unity #3
note
  • has 3.5mm bullets instead of the usual 4mm.
  • xt90
  • does not include box or power button.
more pics
#66 Stormcore 100D+
more pics
#67 Apex Jump Drives :sparkles:Unobtanium :sparkles:
more pics
#68 Pair of Torqueboards ESC + InfinitySink
more pics
#69 XCELL™ APOLLO™ XT Wide wheels and tires. set of 4
Note
  1. these currently have bearings in them for 10mm axles. If you have 10mm axles you’ll need your own bearings.
  2. 10 of the 20 bolts are 50mm for attaching a wheel pulley. depending on what you use you may need different lengths.
more pics
#70 SRB 78T spur gears and Bearings
note these are the older one piece style.
Bearings are for 10mm axles
more pics
#71 Spintend 75/100 dual 18s ESC
Please note this is likely an early version of Spintends “18s” variants. and it might be better to just consider it a 16S max ESC.
more pics
#72 Kaly DS 18650/21700 Enclosure
This is an eboards peru Kaly DS Enclosure.
see details on their website
This enclosure has been designed fit the Kaly XL deck
it’s new/unused but has a few scuffs from hanging around. see detailed pics
Note there are newer and older (in house) generations of Kaly Decks. This enclosure fits the newer generation
@hoytkid discusses how to identify them
more pics (and dims)
From Eboards Peru website:
#73 Kaly Deck XL2.0 pre 2021
after a bit of a convo, @hoytkid identified this deck as a kaly XL2.0 pre 2021 in house version. (the O.G. decks) it’s slightly shorter than the later generations
NOTE: The eboards peru kaly DS enclosure i have listed does not fit this board. It was designed for the later generation so it is actually a bit longer.
for an enclosure that fits, @hoytkid says:
if you want an enclosure for the [og] deck you have closest one that works is eboards peru trampa enclosure
more pics and info
side view of the composite
(ignore the grip tape pulling up there. )
Note
the eboards peru enclosure seems to be a bit bigger than this deck actually is:
it does seem to line up with the dimensions of this kaly 2.0 deck
#74 12s4p molicel Duck battery, Enclosure and BMS
This thing was made 2021-02-26 by Duck Batttery Systems. AFAIK it was never used. So it has sat the entire time. all 12 cells are at ~ 3.49v
I don’t yet know how to ship a battery. so i’m hoping to sell local in L.A. CA, but I can probably figure it out if needed.
The enclosure is 27.5" by 8" wide.
Note in more pics, some scuffs on the underside of the enclosure from being moved around.
more pics
