How to identify a Kaly.NYC deck
Had a convo on FB in which @hoytkid knew all the answers and I thought it was worth preserving not on FB.
Basicaly there’s shorter and longer versions of the XL 2.0, XL40, and XL50 and the eboards peru enclosure only fits the longer ones.
Pre 2021 the deck is an og shorter deck and white edge and those are one deck style and the position of the inserts depicts whether it’s 2.0 xl40 or xl50
Post 2021 the deck is a slightly longer slightly wider no white edge and shiny style deck and the position of the inserts depicts wether it’s 2.0 xl40 or xl50
Also there were 2 generations of xl50 there was xl50 with top box Esc and 12s12p Sanyo 18650GA CELLS and XL50 last generation that was 12s8p Molicel P42a
The inserts were put in decks in house from the start and the holes are different for the 2.0 enclosure the xl40 and the xl50
[The eboards peru kaly enclosure] only fits on the last generation of the xl decks if you want an enclosure for the deck you have closest one that works is eboards peru trampa enclosure
