moon
1
Thread Rules
No discussion about part weight. Only pics and text. First few posts are categorised and are wikis
View only Spreadsheet (WIP)
Decks
Enclosures
Pneumatic Hubs
ESC BMS Batteries
Motors
Tyres and Inners
Trucks
Urethane Wheels
Gear Drives
Belt Drive Components
DIY Board Weight
Fasteners,Bearings and Connectors
moon
2
Decks
Choo Choo deck (without enclosure) β 1.68 kg
Thank you @A13XR3
Landyachtz Switchblade 38" β 2.08 kg
Bustin Sportster (e-core) β 2.15 kg
Lacroix Prototipo
thx @moon
With enclosure:
Without enclosure:
moon
3
Enclosures
Eboosted bustin sportster mk 2 β 750g
Eboosted Switchblade 40" β 708g
moon
6
Motors
Reacher 5095
Maytech 6355 closed can β 620g
Maytech 6365 Closed Can
Maytech 6374 closed can β 860g
Lacroix 6396 Closed Can
SSS 56123
SSS 56114 with 63mm adapter
moon
7
Tyres and Inners
Ali 6x2 Clevers
AliExpress 8β tires Β±20g
Trampa 8β Primo Alpha
Trampa 9β Mudplugger
Aliexpress 8" Inner Clever
moon
10
Gear Drives
Batch 3 Moon Drives - all bolts excluding the ones for the hubs
Etoxx Maxi helical gear drive incl. all bolts.
moon
13
Fasteners, Bearings and Connectors
Andy87
16
MBS F5 binding with 4x M6x15 bolts.
NESE Modules
370g
2S2P 21700 V2 Vented module in PETG - scaled 101% for P42A cells
All hardware (from AM Tech)
Molicel P42A cells x 4
522g
2S3P 21700 V2 Vented module in PETG - scaled 101% for P42A cells
Molicel P42A cells x 6
Tyres and Tubes (another data point)
328g
Ali Clever 6x2 road with tube
(of the four I have, I measured 314g, 316g, 312g, and 328g: avg of 318g)
396g
Ali Clever 8x2 (200x50) knobby with tube
Hubs
272g
MBS Fivestar
MBS bearings (2)
Bolts and nuts (5 ea)
Boardnamics 12mm ID hub spacer (1)
BMS
60g
Daly 12S
AlexB
22
Rise from your grave, thread
803.8g - 9" mudpluggers on trampa phatlads - (with CST tube and hardware)
