Some rider in our group… do they chunk that easily?! Under what circumstances? @Jun
Wow, never seen that before. Maybe defected, maybe drove over a knife?
Unlucky but still rideble.Just put ssome glue and he would be fine. my Caguamas have held up pretty god. no bits falling off.
mine have over 1000km.
Ouch ! The one thing I always heard about blue cags is that they chipped rather easy but for some reason mine held up quite fine, I ride 50/50 on sidewalk and the road and there’s been 0 chips after 200km
Did you pay 200 USD for the teamgee wheels?
No bro, someone else from my Insta followers did. He did the weighing.
Because the PU is very soft is easier to breaking apart for impact.
That’s why we are counting on you to make soft, bouncy and strong wheels!
I tested today all my PU/airless rubber wheels and I would like to give you an idea of my impressions.
Here are the wheels that I tested from 90mm to 120mm
90mm Teamgee
Comfort: 6/10
Grip: 7/10
Range 8/10
TeamGee 105mm rubber wheel
Comfort 6/10
Grip 10/10
Range 3/10
107mm Flywheel
Comfort 8,5/10
Grip 8/10
Range 4,5/10
110mm TB
Comfort 9/10
Grip 9/10
Range 4/10
120mm Foamies
Comfort 9,5/10
Grip 7,5/10
Range 3,5/10
What I didn’t test today but I would rate from my mind is:
Old 97mm 76A Evolve
Comfort 5/10
Grip: 5/10
Range 8/10
New 97mm 76A Evolve
Comfort 7/10
Grip 7/10
Range n/a
Orangutang 85mm 77A blue Caguama
Comfort 6,5
Grip 7
Range n/a
Chunks I had just with 107 Flywheels and 97mm Evolve, but especially on the 107’s a lot.
May favorite wheel is the TB 110mm 74A by just a very small margin over the Foamis. On kart race tracks or slick surfaces I rather go with the TeamGee rubber wheel though. Through hard and loose, dry, rough terrain the Foamies are king. Trough wet, slippery, soft terrain the rubber wheels are best again. For smooth tarmac I prefer the TBs or even smaller wheels like the Cuagamas or 90mm TeamGees.
I never had the opportunity to ride red 100mm Boas though.
Hope I could help
About low range on cloud wheels, I assume you did not adjust wheel pulley size to keep pulley / wheel ratio approximately the same?
Cos if not, then it is not fair to give low range rating.
I used the same pulley for 107s and Cloud, Cloud wheels resulted in 29% less battery/range after testing the same route
At the same speed the lower ratio would even have a lower consumption. So yes, the range is justified.
But I have 32T pulleys for 97mm, 36T for 110mm and 38T pulleys for 120mm. So no worries, I tested a lot before I came to this conclusion.
Of course the range is justified. Just that I prefer to compare range with adjusted pulley ratio kept the same and that will show if the rolling resistance is still good or not. Just a different comparison preference.
Instead of doing a lot of testing, I just use the esk8 calculator and change the pulley size until speed is the same as the smaller wheel with it’s own pulley
I had to go from a 29T pulley on 107s to 36T for clouds to keep the acceleration similar, it drags on the ground like pneumatics do.
Anything that has a grooved / bump design will cause greater drag resulting in worse range. It’s been tried and tested… essentially the contact between the road surface and the wheel constantly goes into a start stop, start stop friction-filled motion, causing that whirring sound, and producing that drag.
Thanks for the detailed breakdown of the ratings! Very useful - have you thought about a rating for acceleration as well? Generally speaking - one would think that smaller wheels give greater torque
Speaking of that, the noise the foamies make at 35+ mph is nuts. Sounds like all terrain truck tires on the freeway
Yup. I forgot how quiet my board was until I went back to regular thanes. I was able to get pretty close to people before they turned around. Got used to that buzzing sound after a hundred or so mile with true Foamies/Clouds
Recently I am kinda intrigued to get the TB 110mm arctic blue version, anyone has any photos of it after some use?
Curious how the translucent thane holds up against use
That explains why I finally got my battery to hold for 30km as it was only holding 20km before. (switched from rubber wheels to harder wheels)
That’s crazy
