That might make people so annoyed that they TRY and hit you lol
Nobody said the weird ideas needed to be good LOL
Do people still listen to radio? Even in cars it’s been mostly replaced by streaming services.
I think a lot folks do, but honestly… we need answers. What are the numbers?
But probably the most likely drivers to hit us are younger drivers who are texting…and most likely to not be listening to FM broadcasts.
i have it on in very low volume just as white noise background when im driving, and sometime turn it up for traffic news
That’s fair, I used to listen back when I had a commute, but that was also because it was either radio or the built in CD player, and I didn’t have any CDs.
It got annoying though because I live sort of in between two hotspots, so frequencies would cut out or change to a different broadcaster depending on where I was.
Can you turn a DKP truck into “TKP” by using rigid spacers instead of bushings on the roadside linkage? The hangar’s still going to be offset but I’m thinking that’ll only make it more stable.
NGL I’ve thought about this too much but hear me out:
Drop a onewheel on top of a snowboard so just the wheel pops through the deck.
Cover tire in tread/studs/chains.
Replace imu esc with one that takes a remote.
E-snowboard and sandboard in one
I’ll likely need to reinforce the snowboard deck at the cutout but who’s in?
Top mounted trucks with springs that push the wheels down but won’t lift the board
You can turn DKP into TKP by getting an ownboard zeus baseplate, or some of them you can just remove that middle segment and it also works.
ive had a very similar idea. but with 2 wheels, and balloon tires. for the beach.
Yeah, but that also reduces the wheelbase which would cause wheelbite in a lot of instances, particularly with AT wheels.
Errr yeah that that point idk
One of you smart dudes should make a new crypto called unobtanium and we should migrate our entire market to it, and make lots of money while we’re at it.
Disclaimer: I have no idea how crypto currency works.
Edit: Actually, could that defeat the dreaded VAT??
Bring back the balut core but make it not suck.
I want my wheels to look like this
Infinity mirror
welp, there is the word infinity in it, @surfnacho is probably on it already
That’s not too difficult actually. Might even make clouds look not so ugly. You know what? Actually, the easiest way I can think of would be… Bolt on infinity mirror hubcaps. Full circle, baby!
(20 bonus points if you power them via qi pads)
