Weird theories and ideas thread! any ideas welcome
this is a thread for any weird and wacky ideas which everyone can discuss and add to.
this is for things which probably wont work or are just ridiculous but would be interesting to talk about.
to start it off
what about some way to have sonme sort of system you could carry around and charge your battery pack through petrol.
no idea how it would work but interesting to discuss and think about
add any ideas weirder and whackier the better
It’s called a generator.
Christ almighty
a all terrain wheel that clips on to a street wheel. No change in pulleys or gears. just clip it on
Rear differential so you can use one big motor to power both wheels
I suppose gear ratios are what stop this right now? Doesn’t seem unfeasible otherwise. I bet one of these guys has tried it
This was explored a bit in builders and became quite heated, as you can imagine :joy:
Tldr: the cost and complexity of building a dif would simply not be commercial enough for anyone to sell. A few people said they might give it a go independently for science.
You also lose the redundancy of a second motor for loss of braking in the event one goes down. Might as well just power your toe wheel and call it a day?
The problem with this is you kind of need more torque when it comes to all terrain and off-road.
And a bigger wheel you will lose torque with the same gearing as the smaller wheel.
It’s a lot of work an extra parts to break for not that great of results.
The only reason we use one engine to drive multiple wheels on petrol cars is because the engines are huge.
Even electric cars which have plenty of room for differentials use multiple motors.
Something I think that would be really cool is a drive system that disengages when you’re not accelerating for free roll.
Maybe it doesn’t even use the motors for braking.
I did, used a coupler nut.
Didn’t really work out. Had to loctite everything down, which makes adding/removing is difficult.
started to think it might be possible to make a cheap ass leiftech clone using some China hubs or a mini onewheel
EDIT: @BigBen its all your fault lol
Most electric cars still use differential’s. There are very few that actually use hub motors or independent motors for each wheel.
Do you have a flux capacitor in yours?
I have an idea…
An eskate company that makes an innovation and DOESN’T scam the community
I thought heavily about this last year but in the end realised it was cheaper and easier to buy a leiftech, but then I wanted to mod it, add vescs etc which i thought the V2 would really benefit from. Now they have the SBX coming out which looks like it has addressed most of the issues with the V2.
You can buy the SR360 plates from Leiftech and DIY your own but they are quite expensive. Aaron from Leif said they will cost 1/3rd of the price of a complete as they are the most expensive part on them to produce
@Halbj613 Yah there are options for longer trips or recharge on the go but basically all either swap out batteries or carry extras you can charge the ones on the board from but really limited by the 1C limit for incoming current while charging so stuck waiting at least an hour between charges no matter where the power comes from in the end (assuming you don’t want to do some sort of battery swap or charge at higher C rating likely reducing cycle count on the cells)
On a full charge with 185Wh battery on a single drive with urethane wheels I can ride for about 12 miles and do it in about an hour but that is a pretty long time on the board for me and usually feet hurting by the end of those really long rides so not sure I’d actually want much more range but I made my batteries easy to remove and put back on for the purpose of having backups I can carry in a bag if I ever need to take a longer trip and so I can swap between charging each pair of batteries to not have to wait for charging.
what about using quick release latches o rc car pins for mounting the battery enclosure for super easy removal when swapping batteries or charging lipo’s
Have used these kinds of clips for RC car stuff before (holding the plastic shell on) but I kind of doubt they are robust enough to hold the batteries on with all the vibration (I guess if you have enough of them clipping it on the weight/forces are distributed but ones I’ve used are very thin gauge too). The idea of a locking pin still isn’t a bad idea I’ve been using backpack straps:
I just used washers and 3dprinted part between the washer and strap to bolt them to my board. Just using washers they would cut into the straps but the plastic printed part distributes the force across the entire strap so they aren’t getting cut into anymore:
Google Photos
I used them to hold the hood and fenders on my old drift car…
Have to guess the full size pins are bigger than the RC ones :slight_smile: (they were basically paper clip gauge)
A spoiler to go faster.
