Try @dickyho
https://www.aliexpress.com/item/3256801083621739.html
5V, flat, momentary
Plenty gracias to you, good sir
Anyone have any extra black king pin nuts they donāt need? Mine have gotten tarnished and my local skate shop didnāt have any in stock, and the hardware store only carries them in plain metal without the coating.
Also anyone know where to get new pivot cups? The ones at my local skate shop were all too small for my base plate and the ones Iāve got now are worn out to the point that the hanger is looser than it should be in the pivot cup which seems like it could become an issue. Feel free to let me know if it isnāt a problem, or how dangerous my current ones are
It helps to know where you are from. Remember to add this to your inquiries and or your profile.
Was about to link riptide as well. @ApproachCautiously if your baseplates are Paris v3 or Caliber 2 I have unused stock pivot cups leftover from when I swapped to riptide you can have
I have some generic ass base plates which is part of the problem as I donāt know what will fit or not. Riptide doesnāt list any measurements on their pivot cups either which doesnāt help.
My current worn out ones look to have an outside diameter of 17mm and then the height from the peak of the bottom to the top is around 17 mm as well but itās harder to measure so that could be off.
The hell hole known as Texas.
They donāt list any of the dimensions on their pivot cups and I do not have a name brand base plate on my board. Unless there is some guide on the pivot cup sizes for each brand I canāt order from them without risking getting the wrong size.
Need a set of MBS matrix trucks with motors mounts for 63xx flipsky motors shipped to toronto, canada
nvm found a set.
Iāll quote this again
I too am looking for this shipped to Canada, if anyone has multiples. Or if @vegr0 maybe letās try having a Canadian group buy.
It didnāt tag you in my reply, but Iām in Texas. Please send cool thoughts to my board
it needs it after hour or longer rides in 105+ f heat
Edit: It is also now in my profile
it did tag me, no worries. My second reply was directed at @vegr0
I called and gave them the dimensions of the bushings on my trucks and they told me which ones to buy.
They were super helpful.
Does anyone have a couple of jst 2.0mm pitch female connectors with 8 pos they can send me? Iām having a helluva time finding these. Trying to make some bluetooth modules. TIA
Does anyone have an old meepo v3 battery enclosure? Or v2 I think? The square boxy one.
@AviatorEsk8er had one I believe, the V3 is boxy with the USB port and voltage display
Thatās the one I need! @AviatorEsk8er you got one you can part with?
