They were for the old FlipSky motors, I think they are the same ones. I used to have some of the TB ones but I have no idea where they went
@kadeanderson I can measure them for you if you have a reference dimension
As long as they are decent quality! Don’t really meet them to be long @ZachTetra
I mean they are good enough to use, just don’t go hacking at them and they will hold. PM me your address and PayPal however much you think they are worth (slow shipping is $3, fast is $8)
Anyone got a 6374 can that works, mine even after hardening menaged to start to scrape the stator at certain rpm
missing another m
Looking for a motor keyway here.
Located in CA 92880
Location would help
Torqueboards sells motor keys
@chsknight
When I lost a key a few years back, I just took a precision screwdriver bit and grinded it to specs
You can also obtain the cheapest 3mm drill bit that money can buy and snap the big end off with a vice
screw extrator set? local machine shop? I’m sure someone can get those out of there.
Yeah I should’ve looked into that I ended up buying a boardnamics set of mounts
Is that TB6 mount extra?
I can fix that
I’ll sell you a good one plus the stripped one
lol just cut a slot into them with a dremel! now they’re flathead
I bought a 6a yz power charger that only outputs 3.9a. So check the output when you get it.
Interesting, I have a 2A and 8A 12s charger and both are within 0.1A
Anyone got some 25mm wide nickel strips I can buy in the UK?
