That’s an excellent point! So because 1 motor was not making contact with ground, it would stop much faster when braking, and this caused the other wheels to lock up.
So even when braking, traction control seems to be slowing down the faster moving motors, which is the opposite of what you’d want anyway! The point of ABS in cars is to not let the wheels lock up; i.e., it should speed up the slower motors, not slow down the fast ones.
I had some really fucky behaviour today from my esc:
Riding in a park, i came to a complete stop, then tried to accelerate and the throttle was mirrored.
And by mirrored i mean pressing forward did the full power control but in reverse, and pressing reverse did the slow duty cycle thing from smart reverse, but forward (???).
Spilled my lovely fanta lemon and launched the board motors first into a tree
I immediately restarted the remote and it did nothing, same problem. Then by the time i opened the vesc tool and connected it fixed itself. Wtf?
After all this i tried the actual reverse function on my vx1 remote and it only mirrors the control knob. Pressing forward starts slowly reversing and pressing reverse launches forward does full power.
How is this possible?
Running fw 5.1 on 4.2 hardware
Nope. Foc and hall sensors.
I was thinking interference from the 200 more people sharing the same alley, each with at least 1 bluetooth device normally. But it doesn’t explain launching full speed backwards
Riding with a free-spinning motor going full-speed isn’t the worst thing in the world.
It sounds funny but it’s not using very much power. I’ve rode home more than once with one motor free-spinning. The worst part is the noise it makes. If you get over that mental block, it’s really not doing much damage. Maybe spending a couple watt*hours but not too many.
For me traction control is the only way to ride with one motor free spinning, if it’s off for some reason I have no power, the free spinning motor goes full speed while the other has no torque, I don’t remember if was the master or slave that broke the belt
The other motor (the one driving you) has full torque, but it doesn’t feel like it, because it’s half as much torque as you’re used to feeling with two motors. The free spinning motor makes a lot of noise, but does little else. It doesn’t rob torque from the other motor in any way. In fact, it barely even robs any range as well.
Assuming you are not using traction control or anything.
No no, I mean when this happened the board wouldn’t even move on the flat ground, I’ve run other times after that with traction control on and no belts on one motor
Now I’m remembering, it was the master, I I’ve posted the problem somewhere
But either way traction control solves it, or if not I think lowering the battery current to 0.5 A or 0 A on the master also made te slave motor works without traction control
Unfortunately when this happened I was riding pretty far without phone to change the settings
