Can confirm it is a sin cos resolver.
We need an inbetween axiom and 75/300 for ecycles and cars that arent trying to break land speed records.
300/75 would be more useful than 75/300. This always confused me
Thereās tradeoffs for both high voltage and/or high current. Component selection for high voltage starts to get tricky while maintaining compatibility with the VESCās algorithmsā¦especially motor detection. Iāve found that bigger and higher voltage power stages will have trouble with Benās motor detection algorithm. Those that made the Axiom have noticed this too. The reason is pretty technical but this will hopefully be addressed.
High current gets hard to manage too. Itās pretty stressful on the components and even small imperfections in layout/design become apparent. Electromagnetically induced noise from the high currents can be quite troublesome too.
When i limit erpm (on both esc sides) to 50.000 in motor settings - general - rpm and cutoff start at 80% and go full throttle on the remote, the side with no receiver slowly ramps down across ~20s until complete stall, while remote side stays full throttle.
Increasing erpm to 60.000 removes this (erpm at full throttle is 52.000~). I donāt suppose this is a desired effect?
Running maker-x repaired esc, 4.10hw, 5.1fw, 2.06 vesc tool, 190kv flipsky motors, sensors unplugged, 12s battery
Edit: traction controll is off, both sides
Look at companies like Sevcon, theyāre producing ebike and car controllers with specs that are gonna be closer to 300/75 than 75/300. I think they only go up to 144v but thatās perfect for a low end EV
The garbage programming for sevcon units and the $350 programming tool steers me away immediately. And kelly controllers are worse than Flipsky for QC.
True that. Thatās why Iām trying to scale my designs up to compete with sevcon and the like. Itās just taking way longer than I thought.
OH wasnāt aware of the issues. Iāve never used them and most older EV conversions take advantage of them. Honestly using a Prius inverter will probably be best way to have a cheap, fairly high power and indestructible motor controller. 400+v 350A on MG2 and 400+v 250A on MG1 is really high, especially for the price, if used
When you sell your sevcon competitor Ill be throwing money at my monitor.
@kalebludlow Iād take an Prius inverter and the whole prius battery system for almost any conversion over sevcon for compatibility alone. Im loving your ford laser project cant wait to see it driving someday. Ive heard Sevcon controllers are reliable, pretty sure thats what the Zero FXs use but I just cant stomach half the price of the controller for a programming module Iāll use twice.
I think zero started rollin their own controllers. Sevcon is ok once programmed and configured but theyāre built more for forklifts and other low-speed industrial applications.
Derail alert. Please choose or create a new thread for this to go into. Thanks.
I have this issue too
I have a different hw setup though.
Both motors spin up to max speed, then one side starts to jerk and decrease speed until its stops spinning. The other side keeps spinning.
That rpm smoothing limit just gave me headache. It was working fine on a setup I had 1 year ago
For now I just removed the rpm limit. You can change the max duty cycle to set your preferred max speed. This removes the problem.
As for torque smoothing at high speedā¦
There is a new setting for smoother duty cycle limit but I have the exact same issue using that one.
Is anyone using this setting and it works?
My biggest issues since switching back to Vedder from Ackmaniac, are ALL related to maximum speed governing. Literally every bug and issue Iāve experienced is related to that.
Itās hard to test top speeds under load, on a bench.
Iāve turned off speed governing on the top end and use it for reverse only, where there are no brakes [or throttle] if you exceed the governing speed.
Did you set it for both motors?
I remember that the speed limit i put in the android app worked really well. It overshoot under no load, but always balanced at the exact speed i set. Do you know what settings that function used?
Yes the settings are the same.
I can make a video of itā¦ sometime during next week. (waiting for a replacement motor)
Just a small report for you guysā¦
-I can confirm that my larger scooter hub motors now can be driven after FOC detection with 2.06 (detection using 2.02 didnt work at all)
-Initially I had quite ācoggyā regen breaks at low speed. I got rid of this by increasing the time constant for ki and kp. But then I got abs over current faults at uphill take offs. I reduced the time constant to somewhere in between and now there i just a little coggy breaks and no Abs current faults.
-After installing 2.06 and running the detection, I had a lots of vibrations. Couldnt get rid of them. Did multiple detections and tried different settings.
Switched to BLDC and back to FOC and then vibrations just disappearedā¦
-Changing the switching frequency got rid of some weird resonance at a certain speed
After some minor tweaking It seems to run fine on these motorsšš»
The latest detection method, included in the latest FW should work a lot better for most motors that were difficult to detect in the past.
Yeah, Iām experiencing some of these. On my scooter if Iām going down a hill and exceed max Erpm as soon as I slightly press my brakes it tryās to buck me off the front. Within the Erpm limit the brakes are predictable. If I was on a board I woulda been thrown off
FW5 on FocBoxes
