Im having a similar issue with flip sky 4.20 plus… bkb 6354 motors… one of the motors is running 35 amps and the other around 50 amps on detection.
Hey @Deodand if I wanna do motor detection on a motor that is larger than 2kg should I be doing it manually? Or just select the 2kg option and hope nothing breaks?
Mister Not-Expert here says he thinks it’s fine if the motor is bigger, just not smaller.
But disclaimer: I’m not responsible for broken motors or ESCs
I only asked as the motor would be closer to 50kg than 2kg, mostly worried about esc
ohhh I know what motor that is
can’t wait to see that build
been following the thread
I only just realised for shits and gigs vesc should technically be able to get some spin, even though my esk8 battery voltage is only 25% of what’s required. Onward, for science!
Ladies and gentlemen I present to you the vesc powered Toyota Prius, coming to a dealership near you soon.
I hate listening to my own voice hahahah
Benjamin also has one in his garage. We just need to wait for the BIG VESC to arrive…
Yeah I’ve been waiting to see what Ben is planning with the bigger stuff, super interested
So the motor is only pulling 2 amps but it’s sitting at 95% duty cycle due to the voltage the motor takes, hence why it’s going so slow. I also can’t get the second motor spinning h because the parking pawl would be engaged.
Edit: oh shit I should be able to connect the motors encoder to the vesc for full foc operation, gonna take the transaxle inside tomorrow for more testing
That’s a nice remote you have there
Connected to MG1 currently as parking pawl applies to MG2 specifically (I think). You can weld some of the gears (planet and carrier? I need to find the thread with the info) to allow MG2 and MG1 to spin at the same speed. I am also able to parallel MG1 to MG2 to get some more power. I’m just doing this for fun and ensure my hardware works
Any other questions can be directed here to not clog this thread: '84 Ford Laser EV Conversion Project
Already have a controller. I only have ~75kw of power so no point getting a higher spec controller. The Axiom is a form of the big vescs that Frank was referring to (I think)
What type of encoder are you using?
I tried using a quadrature incremental encoder with index with the VESC 6 a while back, ended up not working because the index would end up slowly getting offset by 90°.
If it is the same kind of encoder, could I know how it goes? I would like to get it working on mine, thanks.
Good luck on your conversion project!
Does HFI work on that motor?
Not sure on what encoder is in it, will tell you tomorrow when I get it inside and on the bench.
@b264 that’s for tomorrow’s testing
Awesome! I’m guessing it is a sin/cos resolver then.
Good luck!
