I was basically thinking of pouring the entire core solid, and cutting up the shaft like so:
not sure why I would leave one bearing intact, care to explain your thinking?
oh so you mean glue in one side with the shaft and fill it up then pop the other bearing on. That would be good because then I could check inside later to see if it was coming loose! Or glue the other bearing on.
Perhaps I will have to go with like 90KV motors and a tiny reduction, that would give me ultra low rolling resistance for free rolling which would be cool!
Hi,
really interesting topic here.
I see a lot of people has the same ideas to continue to improve the terrible Leiftech (large center wheel, and fitting new Freebord trucks) .
As you can see, no much stays from Leiftech.
New electronic and vintage Freebord deck (I love it!)
I have Alpha trucks on it, and I may fit the new 5X trucks when I’ll get them, but what I really would like to dothe most is to fit larger center wheels. (I heard it improve the ride on rough roads).
I was thinking to have original parts to be enlarged like this one:
but I couldn’t even remove this part from the bearing in the alloy square part (I guess it is press fitted?) Do you need a press to remove it?
Fo those who already have a Leiftech, it seems it would be the easiest and cheaper solution.
A couple of cut and welds on the existing ones.
Your solution looks nice but expensive, but maybe I’m wrong?
can you show me exactly where you get stick in the disassembly? all those parts unbolt easily for me.
what do you think of my redesign of what I’m calling the hanger?
Me and @alexincorsica are using these JMK ride wheels that are also used by Otherboard.
The whole upgrade I would get under $200-250 with motors hopefully.
I was wondering if a motor axle would be a good place to find a 8mm keyed shaft already close to the right length and wow a TB6355 motor hit it ON THE DOT!
I am super happy with that.
I can’t find replacement shafts for a flipsky motor but I could prob contact them to buy them, or this could be an option: 83mm long vs 89mm
Your design seems complicate.
My idea was simple: having the original parts cut and welded back at largest position on the plate (both side of course).
I think it won’t be very expensive.
Of couse, there is still the need to figure out how to fix the wheel, we can go the same way as Nowin (e-toxx) offered to fit Freebord centerwheel on Leiftech.
I switched to the universal motor bolt X thing for 25mm and 30mm bolt pattern motors, and added the BN idler. I realize now I could use an M4 bolt and a metal sleeve on the bolt to fit the 6mm id bearing of the idler, instead of an 80mm long m6 bolt
