I have an acton blink S and it gets HORRIBLE range. I mean HORRIBLE. 3-4 miles MAX. I am looking to build a new pack for it.
Here are the requirements for the pack:
6-8 miles of range
36 volts
Fits in the standard compartment
I am wondering if you guys can help me decide on the cells and which tools I need. I already have a soldering iron. Keep in mind that I am a first timer.
That’s not recommended. You will probably spend a few months and many hundreds on tools just to make one battery, not including the cost of that battery itself. Plus it’s not an easy task to make a SAFE battery. It’s easy to make a bomb by accident.
I was also considering taking smaller packs a wiring them up in series. For example 2, 5s battery’s put in series. How many Ah do you think the pack would need to get 6 ish miles of range?
But if you use the cheapest 5000mAh 5S lipos you can find you might have bad results as they can just puff and die, possibly in a spectacular fire.
You need to get ones with a high enough C rating. Higher the better, and most of the C numbers are exaggerated or straight-up lies, but above 50C or 100C would be best. It’s hard to know for sure since accurate numbers are hard to come by.
