I’m planning to make my first diy eskate over the winter and could use some help.
This is what I have planned so far:
-Zenit Marble 38 v3 deck -12s5p battery made by Z Battery Solutions - custom double stack enclosure by Big Ben -Xenith vesc -2 Flipsky 6374 190KV motors - Boardnamics’ BN220 Adjustable Angle Precision Trucks + Idler Motor Mount Kit -Boa Constrictor 100mm wheels…
Still not sure what exact pulley and belt sizes I’ll need. And still researching remotes.
I found a couple threads here regarding making a diy with this Marble deck so I’m curious what the final product looked for people.
This would be a decent starting point. I’ve plugged in your battery (assuming p42a cells), motor and wheel configuration.
Basically the calculator figures out how fast your motor will spin (12s @ 190kv = 3.6x12x190 = 8,208 RPMs), how much distance one revolution of a 100mm wheel will cover, and then you can input the motor/wheel pulley ratio to calculate your loaded top speed.
A 16t motor & 40t wheel combo would be a good start for a higher top speed (35mph), or even a 16/45 (30mph) for better hill climbs.
I’d try not to go less than 14t on the motor pulley to avoid belt slip, then just tweak to whatever wheel pulley sizes you can find.
If you gear it too high, say 50mph, it will take off slow, bog down, never reach that speed and overheat the controller & motor. The lower the top speed the faster the take-off. 25mph top speed is probably the lowest.
I usually buy one wheel pulley then a variety of motor pulleys so I can tweak it easily later on.
This mount can hold 63mm motors and 50mm motors. For 36T pulleys, a 315mm belt is recommended. For 40T pulleys, a 325mm belt is recommended. A 60T wheel pulley is the maximum size we recommend.
No I mean the physical pulleys. If you use a 20 tooth motor and a 36 tooth wheel pulley on 100mm wheels with a 190kv motor and 12s voltage, you will be “geared” for 50 mph top speed, but it probably won’t have the power to get there and the acceleration will be terrible so that’s a “bad” gear ratio.
If only a 40t wheel pulley is available, start with 16/40 (2.5 gear ratio) or 14/40 (2.85 gear ratio) IMO and see how it rides. You can always swap out a motor pulley later on to give it either more top speed or more acceleration.
You just input all those values into the VESC and it will calculate your top speed based on pulley and wheel size
I was originally planning my build around the Rocket Macro deck, but the wheel base was a little smaller than what I was looking for at the time. Once I found this one I really liked the surf board look and style of it. Depending how this one goes my next one might have to be that Macro deck
Then read and learn about that first, dooood.
Its neccesarry to know about battery specs and how much power they are able to set free. Very important and not that hard to learn if you ask me and im slow like a turtle in learning
I’ve been busy with other projects, but I’ll start soon.
Already have the major components and will start by skinning the deck, then building the 12S5P pack. @JoeyZ5 will do yours right? If he starts first I’ll probably steal some ideas
Drivetrain will be BN AT GD with 6’’ tires, as usual
