So another epic track day in NL last weekend. Great turnout from all across Europe. We had dudes from Czechia, Germany and even NZ in attendance. We were privileged to have @xsynatic there as our celebrity guest of honour. It was also really interesting how few of the people I met were actually aware of this forum - blows my mind. But yeah, lots of different forms of vehicle doing the rounds and all with (at least) one thing in common: we were all sliding all over the place (like this and like this).
You can see in the first link there that the track is quite shiny along the racing line. It was also really dusty and quite sandy in places.
Track days are normally extremely physical because of the huge forces you’re constantly managing, but in this case, the forces were kept relatively small because you couldn’t go in so hot. But trying adapt the technique, weight distribution, throttle/brake balance etc. to the slippery circumstances so you could make it into, around and out of the corner without breaking away turned out to be equally tiring.
So mad props to @esk8manbabes for humiliating the rest of us with a win that put him 2.5s ahead of 2nd place (and 9.5s ahead of me) in the Esk8 AT category.
He and I were racing very similar setups so it would be easy to conclude that he is the more skilled racer. There’s no way I’m going to accept that explanation though so I’m zeroing-in on the one key factor that differentiated our setups: the tyres.
I was running practically fresh Evolve 175s. He was running brand-new AliExpress 200mm ATs. My tyres had a nice fat contact patch. His had a fairly narrow contact patch. The rubber compounds felt more or less the same. Certainly his weren’t as hard as the usual Ali AT fayre.
Conveniently enough, Mikey also weighs a bit more than me so I can put these two factors together and conclude that, since mechanical grip is a function of pressure and Pressure = F / A, he just had more grip. Case closed!
But alas it’s not that simple. For a start, he also did really well in the Street/PU category whereas I could barely complete a lap. Secondly, it turns out that rubber’s coefficient of friction actually reduces with pressure due to plastic deformation and tearing. Plus it begs the question: why would race cars (and LandSurf customers) choose to have such wide tyres if it didn’t improve grip?
So I wanted to open this thread to get more informed expert insight. Is there a way to determine the best tyre for your weight, setup and track surface? Is there a point at which you’re actually better off with a narrower tyre than a wider tyre? What else can be done to adapt to more slippery conditions and to prevent another humiliating defeat?
). Where the conditions are mostly shit. gravel, sand, wet leaves, snow, water, salt, dogs, cigarettes, chewing gum. You name it we def have it. How is your experience regarding the looser stuff. As that is what I normally loose traction on.
