@torqueboards are the current stock of 110s cores flipped? Or has that been resolved?
I have two question what are the wh/km people have seen and are their suggested hearing or is 16/36 I live in a hilly area
Direct drive, I get 13 wh/km on average when riding relatively easy on my 74a TB110s.
As for gearing, gear to the highest speed you are comfortable with and will actually ride at. The highest gear ratio you can achieve for your desired max speed https://calc.esk8.news/ will result in the most efficient ride- otherwise, gearing too low will mean lost torque for speeds you wont reach at the top end and wasted battery amps spent making up for the lost torque⌠hence lower efficiency. Also, watch your belt tightness (not too tight, not too loose) and prevent skipping with a pulley that keeps itself centered (bearing in pulley, not bolt on) as opposed to tightening belts further (over tightening will reduce efficiency even further).
Hope this helps, happy skating man.
Exactly what @Skatardude10 said except my for that I usually gear for 2-3mph more then I want so then I am not at my gearing limit just in case I need the extra speedâŚ
Hey @torqueboards, do you already have a color in mind for the 72A wheels if testing goes well? I was thinking translucent purple, similar to what the 74A wheels have, would be cool
I saw maybe white so people can dye them to their preferred color
The prototypes are always a different color for some reason
72a tho, talk about squishy
Squishy they definitely are
Whatâs with the orange did you dye the blue 74a 110âs
They need to be red and nothing else. I have no reasoning to back this up. Red, tho.
Youâre drunk bill we are calling you a cab
Just everyone make sure Wandagoner doesnât get in with me.
(Red, tho.)
Interested in a 74a black has anyone dyed the blue wheels black
An orange translucent would look pretty cool I thinkâŚ
Iâm also super interested in some black 74a wheels. No ETA from TB on that option thoughâŚ
@rafaelinmissouri is the only person I know that has dyed the arctic blue wheels black. They turned out pretty good.
Yeah I saw a picture in the picture thread it must have been his they looked awesome
