TorqueBoards Direct Drive Motor Kit
You’ve seen this thread right?
Yeah, but that requires functional axles, which I don’t have.
I have some. I can send to u for cost of postage if u like. But I’m in Australia. I sold the board a while ago so just lying around.
I appreciate the offer! We’ll see what dex’s timeline for the steel hangers is. If its far, then i’ll likely take you up on that
I hope u have better luck than me. I’m not exagerating when I say i waited over 6months for Dex’s ‘stronger’ one off hanger he said he’d do for me.
That’s why the Radium ones came about. I kept bitching in an Australian FB thread and Glyphiks got it going for me.
Best of luck. Wouldn’t be surprised if they’re just sourced through Radium lol
Is he asking you to pay for the “hypothetical” steel hanger?
Nope. He’s telling me I can wait for them, then buy
We have a batch of steel hangars coming in about 3 weeks. Probably the last batch too
I just did motor detection through the stormcore, sensored FOC. Can I confirm that 64 milli-Ohms and 32 amps are normal for these 90kv directs? I thought that the resistance was perhaps a bit high.
I got similar results for my 85kv drives
Are my drives acting right? There’s quite the rolling noise in slow speed and non-trivial amount of vibration at max rpm. 95kv.
I think it may be chattering on the truck. Theres a small patch of double sided foam tape that holds motor to truck and sometimes it loosens. Re-taping may help
Do you have a specific thickness in mind? The gap is extremely small. Also, I heard that you were supposed to use thermal tape?
I’m not sure. There’s a video earlier in this thread (June 2020; 276/733) from Torqueboards showing the fix.
I am still somewhat paranoid. I narrowed the vibration problem down to just one of the drives. When I take the motor out of the axle and spin it in my hands(the vesc driving the motor when I am holding it by the inner shaft) I can confirm that the motor is in fact vibrating a non-trivial amount but the vibration is for some reason intermit. There was also some noise inside the motor(light brushing and clinging on the can) but it seem like opening the case is impossible unless you have the right tools. It would vibration hard during low to medium speed, vibration only a little during medium, and vibrate hard again during full duty. Is there some reference vibration/sound that I can compare my drives to?
Have you seen my teardown thread? I get weird noises running sensored in the beginning but otherwise smooth. I think that’s normal anyways. While annoying to deal with, there’s no reason you can’t eliminate the problems on these drives. Other than them having some serious tolerance issue, but you should be able to locate it.
Here’s how they should sound and early similar dogshit
What’s your VESC Setting? My TBDD have really weak break in steep hills =/
TBDD are not the strongest breakers. Here are my settings.
  1. motor max current: 80 (range: 70 to 90) adjust for low speed torque
  2. motor curr max break: -65 (range:-60 to -70) adjust for low speed break
  3. battery current max: 50 (battery max continuous 100A divided by 2)
  4. battery current max regen: 16 (max charge current 8A * 4p = 32 divided by 2)
  5. voltage cuttoff start: 40
  6. voltage cuttof end: 36
  7. ERPM: leave limit at 100,000 or change?
    Save and then repeat for other side
what cells are you using? seems like your brakes are easing out rather than the drives being bad breakers.
to be clear, I’ve broken every set I’ve had, but I think you mean the other kind of braking.
molicel p42a. what would be a better setting?
