cross posting because i’m an impatient child who needs constant validation and attention
if i recall correctly the housing can be a bit of a challenge to remove and hoping some better seasoned may offer top tips
I’ve been thinking about this for a while now. I want to keep my drives in good shape considering they cost me more than a decent pre-built.
@torqueboards are you planning on releasing some maintenance tips and/or tutorials (videos or articles)? What about spare parts like bearings or new motor cans? I know your primary focus is on producing the direct drives, developing new products, and keeping up with customer service but it would be a relief to hear from you!
I’m confident they will hold up to some serious abuse and “thousands of miles of exhilarating fun.”
@ThomasL - XL version are 6380s. A 6396 is basically the same size motor as a 6380. The only difference is an added bearing and a bit more added space to secure the motor shaft.
Unfortunately, the TB DD XL hanger length is too thin and too long IMO. For it to be more durable, we’d need to use a larger motor as the inside diameter of the motor is otherwise too small.
@Wandagoner - You can use a rubber mallet and ATTACK
the inside collar of the motor. This will release the motor from the truck.
See photo here https://www.screenpresso.com/=oEjic
@Meeep - For the most part, I’d keep them dirt free as much as possible. I wouldn’t recommend riding in the rain. I typically like to use belt drive for rain as things are easily replaceable.
I would re-oil bearings once they start feeling dry. To replace the actual bearing would require a jig and press. If you do have issues, let us know.
Thanks Dexter - i already have the motor dislodged from the truck. i am now trying to remove the housing to fix, what i believe to be, a loose or broken magnet inside the motor.
are you able to provide guidance on removing the housing?
@wandagoner - would require a jig and press. Send us an email with a video of the issue.
thanks Dexter. i’ll conduct some additional testing to ensure its not esc or software related before sending along to you and your team
Hello guys,
I put my new 110MM wheels on my never used Torqueboard DD and one motor is loose on the axle creating quite a bit of play. Nuts are not too tight or too loose, and the other motor is really smooth and fits the truck perfectly.
See the video :
Is this a known issue or is my motor / truck bad?
@torqueboards
Thanks
It’s not really an issue. I have the same thing, it causes some chatter, but it’s only sound, nothing to be alarmed by.
You can take the motor off and glob some thermal paste in there, it will help with heat transfer as well as dampen the chatter. alternatively you can shim it with some thin tape, kapton or electrical tape, whatever fills that (just square part) gap a bit and you will be good to go.
WHat @Skatardude10 said. I put a lil piece of electrical tape and stopped it all completely.
I will try that, thank you @Skatardude10 and @Jansen.
to pile on… i used some thermal tape as i found 3m “33” tape was too thick.
https://www.amazon.com/gp/product/B075FR45DV/ref=ox_sc_saved_title_5?smid=A2UPOYF43ISB1E&psc=1
A few days ago I drove around again with my TBDD build after a long winter break. Still the best decision i have made.
Me too. Absolutely in love with this motors
That makes us 3
still wish I had the 75kv instead of the 90kv, managed a top speed of 40mph once, scary as hell
Hey guys.
I am new here. This is my first time building electric skate and i would need a lot of help. I have just buyed 90kv direct drive motor and 12s4p battery pack. I am struggling where and how to connect all wires from motor to my TORQUE ESC BLDC. I have conncected black blue and yellow wire, but where do i need to connect 4th.
How do i connect my esc with nano remote controler?
How do i connect 2 esc with each other?
How do i programm esc and what settings should i select?
list of parts:
90kv direct drive
12s4p battery pack
2x TORQUE ESC BLDC ELECTRONIC SPEED CONTROLLER
1x VESC CANBUS
2x VESC male to male
1x 2.4GHZ NANO REMOTE CONTROLLER
1x mini uscb cable
I am grateful for all information and help
Please ask some questions here
And also start your own build thread
@BillGordon might be nice enough to bump your account
You can just connect the three big wires (for each motor) and set up the ESC in “unsensored” mode if you want to. In fact, I recommend it.
Offtopic but I find it a bit ironic that you’re willing to use FW 4 for the HFI feature with some known issues rather than Ackmaniac and a sensor in the motor.
I mainly use Ackmaniac 3.103 without sensors. Only one skate has 4.1 on it, as a test.
Hello Dexter @torqueboards,
I have an issue with one of my motors. It has never been used or even plugged to power for now. While mouting the 110s I saw that one motor have a weird resistance when I roll it with my hands :
One is very easy to roll, very smooth. The other is harder to roll and even become harder at certain part of the rotation.
Thanks to many helpful advices on the noob questions thread, here is what I tried :
Tested making sure the phase wires are not touching
Checked the phase wires resistances with a multimeter, everything is the same on both motors
Checked if the kegel adapters screws were not too long / did damage anything (It does not seems possible using the screws you included anyway).
The axle nut is not too tight, in fact the resistance is still there without wheel or nut.
Should we arrange a return or do you want me to test something else before ? Could this be an issue with a magnet / windings ?
Thanks.
