Thank you!!!
I’m running unsensored on the Torque 6’s right now and you honestly don’t need the sensors at all. With the updates my board is running like its sensored without it. Save the time and don’t program it if you’re buying these.
66℃ does not seem excessive to me.
80℃ is hot, 90℃ is really hot, and 100℃ is the do-not-exceed temperature.
I think you can only reach 100c only if you change default temp settings in your vesc. Otherwise vesc won’t let it go higher than 80c.
68c is still ice cold ![]()
Ha! 99c! And it immediately cut me out lol, I swear I’ve take them up to 105…no Bueno tho
Hello
Wondering if this esc is turning out to be any good ?
I am using them, and they are good.
I second this ^^^. Put ~1100 mi on my set and zero issues
They are 12S/13S max, right?
60V parts means 12S max, yes.
Some folks run 13S on those parts but I don’t think any quality manufacturer recommends that.
Has anybody tested them with direct air cooling?
yes. They are insane
Mine are running inside sealed enclosures. Interested in this as well
Might be worth a consideration then. I run my vescs open so the more i ride and the faster i go the cooler they get. I want the same effect on these obviously
Just gonna drop this link here
They will be better with direct air cooling. You can run them much harder.
Thanks Brian! I got extras, so if people need a heatsink I have them covered.
Is the final price known already?
Or even a tentative release date?
@torqueboards
Are these the final outer dimensions? 80 x 70mm?
What is the height?
