Yeah!! Maybe Iāll try doing that today.
Iām not very good in the whole nerd department. I mean. I know how to work my way around vesc tool but never done the whole ābootloaderā deal. Any help will be appreciated
Just like FW loading just go into the bootloader tab and than hit upload.
Awesome. Seen that but didnāt wanna do something that will compromise the vesc lol.
Thanks brother. I appreciate the info
Canāt promise it will fix it, but worth a try in my humble opinion. You probably need to do that for each vesc separated if I remember right. Havenāt done that with the lates FW so maybe things changed a bit.
Well give it a shot brother. Thank you.
This is why I should stick to Unity. Iām straight up dumb
this is also why im still stuck with unity, until the stormcore app has an android version ![]()
THERES NO ANDROID VERSION? So Android users arenāt able to use the StormCore at all or theyāre stuck with vesc tool?
no android app yet for stormcore, either vesc tool app or get an iphone, and i choose none of that lol
I would rather die
The good olā tcp bridge
Or you canāt stop yet, youāre not done.
Iām beyond DONE. I am Mike
Too soon?
UPDATE:
I had a friend walk me through the vesc tool, just a fun refresher. Always good to check yourself. Anyway.
I went through, wiped the escās to default, then re-installed the firmware on both without being connected over CANBUS. Then, instead of programming the motors over āotherā motors, I ran the FOC detections despite not having FOC sensor wires. Why that actually worked? No freaking clue. Then we saw that when switching to BLDC in the General Tab under motor config, it inverted the wheel direction. Weird again. Input had to go through UART bc Flipsky VX2. So playing with the motor config more, we switched over from using the computer VESC tool to the mobile app. Ran through the wizard again FOC to get the motors to communicate over the CAN. Then, we switched to BLDC through the app, and the data is where it should be. Top speed, range, etc. are all solid now on the app, and I seriously love the ability to program it on the fly where or when I need to.
Thank you all again for the help and space to air frustrations, Iāll inevitably be here again at some point to ask some sort of question.
Would like an answer to this thoughā¦programming detection through FOC worked. The remote powered both motors, and it was quieter and seemed smoother than BLDC, but I donāt actually have sensor wires. Would that have been unsafe to ride?
Sensor Wires arent inherently for FOC or not. So this is irrelevant.
Likely this is HFI doing its thing, this would be expected in my opinion if youāre on V6 hardware (and using FOC).
Edit: clarifying statement
You can use metr and use TCP Bridge to allow the use of VESC Tool on a computer.
You can also do that with the VESC Tool Android application, but itās less stable in my experience than the metr software.
Battery-12S8P 40t
ESC- Dual TB6 VESC
Motor- TB6380 190k unsensored
Tires- 8inch Primo Stryker
Whatās the best way to reduce ESC heat besides a heatsink? Since moving from 6374 sensored sealed Maytechs to TB6380 unsensored I have noticed a jump of up about average 10c degrees. Do sensored motors normally heat up the ESC less or is the extra heat coming from the higher rated motors?
No
Maybe
What were your settings on the old motor?
60/-40 motor
45/-12 battery
The temp stats from the metr log seem a little excessive, no?
FOC just means it drives the motor by smoothly changing the direction of the force vector applied by the magnetic field. Once the board starts going, it can figure out the motor position without sensors fine. Without sensors you will just have a bit of a bumpy start, probably requiring you to push the board with your foot a bit to get you going. (Although I could swear that on some firmware versions Iāve had unsensored FOC start up smooth as butter, no HFI magic needed! )
Itās perfectly safe to run FOC unsensored, I always prefer it over BLDC ![]()
