You should have enough clearance… I guess it depends on the speed-bump.
I should mention that the Odashi is available without carbon fiber. Just incase you don’t like CF. It costs $90 less. Just let me know. I haven’t put that on my site yet.
What’s the clearance on the one I got from ya with 8 inch wheels?
It’s very similar to the Odashi, 2-2.5”. I forgot… which trucks are you using?
Boardnamics 270mm with adjustable baseplates
Those ride high. You’ll have a little extra clearance.
One more question - what angle do you recommend I run for the baseplates?
Somewhere between 10-20 degrees.
can I fit a 14s8p setup in the double stack enclosure? ![]()
Yes, but you have to measure your ESC and BMS to make sure they’ll fit in the remaining space.
Can you make Video frome the Odashi: 44" and jump and show the Flexybility from this board ?
THX
I can probably do that, but I can change the flex of the deck. After someone purchases a deck, I contact them and ask a bunch of questions to see how to customize the flex.
Okey …
You can make video 3 difrent typ of boards, withe the same person 80kg .
Thx sascha from switzerland ![]()
I only have one model at the moment, but it’s your lucky day… I just so happen to have an 80 kg human on hand to jump on shit ![]()
What kind of flex are you looking for? What trucks are you going to ride?
-Matrix 2 withe e-toxx variable adapter
-boardnamics m1-AT drive gear
-e-toxx hubs.
Are you trying for something stiff or for something with some bounce to it?
@tomiboi was a pleasure to work with answering all my flex questions before I ordered my Odashi. I was definitely looking for something more flexy.
i think best way is show me you normal Flex Board on Video.
Make pleace realistig Video withe Battery Case.
To this moment i have exway Flex, this is realy Flexy. I love this.
I drive Flipsky 6`` Wheels 50kmH Speed.
I Want More Speed 80kmH and e Snowboard Feeling dont miss.
I am to this time 88kg withe Stuff i am 93kg.
Dont forget the Big Battery 8kg.
@tomiboi just measured my board and realized my MTB deck is 40.5” and not 41.5”. The schematic shows it as 1029.5mm so I assume the 41.5” is a typo. It’s all good - I just wanted to share in case its something that should be changed on your website.
Thank you. lemme check to see what the length of the most recent shape is.
