LoL “debunked”
That video was “debunked” the same way that this map is accurate.
this also shows the earth is flat…right?
we came to the conclusion that the “delay” that @xsynatic was talking about is in fact the motor powering down by decreasing the power slowly instead of cutting it all at once, this can be tested by hearing the motor spin at lower rpm after you let go and feeling it while you stand on the board, furthermore if such a delay was actually present instead of the ramp down you would feel it when doing other things such as accelerating and braking, but it clearly is not there, you can also bypass the whole ramp down by braking, which means theres NO delay from the remote
so tldr: no delay, case closed
i rest my case
Of course. Additionally, Antarctica is the only continent. Everyone knows these things. Duh
Look how big the Pacific Continent is
i knew it!!! i knew i had to be living in the same continent with the penguin!!
can we not bring the ocean into this
Hello my name is Ryan and I need help with my build I have 36v xaomi batteries (I bought them a long time ago but I bought 36v 10S4P 18650 Electric Skateboard Battery W/BMS/Charger instead) I need help setting everything up it keeps telling me low battery and the motors make weird noises I’m using a stormcore 60D and boundmotors direct drive
Hi Ryan,
We’d love to help you. You’ve stumbled into the closet though. We’d love for you to come in the front door over here.
We’re happy to assist you ![]()
i think i might try to move it there if discourse lets me lol
This,
this ![]()
Annddd…
This ![]()
502 bad gateway oh well.
wrong key bro
i told u to slow down on snoting those sour jelly
On my image you can see an every so slight decline. until it stops accelerating. There’s no rampdown
there is, its probably not in small incremets like 100>90>80 but more like 100>75>50, which is still smoother than 100>0
