I would just drill in new inserts, leave the old in place and just move the enclosure 2-3cm back or forth
but then i have to replace all inserts and also my enclosure perfectly fits literally the whole perimeter of the deck
i might just drill a new hole in the enclosure like 2cm away from the old hole or i might try filling with wood glue then redrill
No one thinks about retapping them?
What do you mean by that
I am a noob with threaded inserts so I donât really know much about them
to recut the thread, if itâs only bent.
Nah the thread is completely snapped and when pulling out the insert the whole insert snapped in half
Filling with wood filler now and then will drill a new hole and put in a new insert
If anyone in the U.K. could recommend some inserts (preferably on amazon) which are good and not ridiculously expensive then please do
Wood glue or wood filler is likely not gonna be strong enough. You really need to use epoxy or similar.
At a pinch you could use these.
https://www.screwfix.com/c/screws-nails-fixings/insert-nuts/cat7280108
They are by no means good but I have used them before.
So this is supposed to be some pretty strong stuff and supposedly you can drill through it once hardened
Just put it in will wait half an hour for it to harden
This one is an epoxy type wood filler a sit is 2 parts one being the hardener
I can drill through cheese once itâs hardened as well.
If it doesnât work I will just either fill with epoxy or go and make the hole a couple cm away
Iâve seen a couple of people here already recommend epoxy⌠dunno why you wouldnât just do it in the first place. But good luck!
Cause the only epoxy I have is jb weld and I am low on it so prefer to try something else and that as a backup
What did you end up doing? I am in a simular situation, tried wood glue and redrilling, tried JB weld and redrilling, and both ways the insert is coming out.
So I loctited a bolt into the threaded insert and left it for an hour or 2
Then when it was really solid turned the bolt and the insert came out with the bolt
I ended up just drilling a new insert hole a couple centimeters away and filling the hole in my enclosure with epoxy. I just left the old insert hole in the deck.
The inserts i bought were complete junk so I gotta replace
You canât get ez lok in the U.K. without spending a bomb
Anyone in the eu/U.K. know where to get some good ones from
Sorry to bring this thread up again
But I bought random eBay inserts and they were aweful
What decent inserts can I get for like a fiver for a lot of 8
Thanks
Yes only use epoxy if your 100% sure you will never get that fucker out (voice of experience) I am doing my M6 inserts on my carbon fibre and fibreglass build âTUBBYâ next weekend just waiting on the M6 fender washers.
Going to use the @longhairedboy method of electric drill sawn off M6 bolt 2 inserts an washers.
