Nice, so those 13000mah ovonics are right up my alley?
Yep. they should be great. What vesc do you have? can it handle 12s ?
I have 2 of these, or had, one is still floating around in the atmosphere. I’m looking for others though. Preferably singles unless a great dual can be found.
i would be very interested in how you wired the balance leads
i have been running the graphene 6s 12A lipos, they kick ass! i have cycled them over 70 times and they still work well. Currently using 3x in series for 18s mountainboard build.
for charging, i use a 22v PSU that can push 15amps, that guy is connected to a q8 charger, i split my balance and XT leads and charge 1-4 in parallel
cool, what do you do to the 2x grounds from the balance leads?
Right around the middle of the connector you can see the positive of one pack is connected to the negative of the next.
Gotcha!! ty
Damn 18s? What’s your drivetrain setup, VESC/ESC? What sorta range do you get?
Haero Bro Stiff
MBS F5 Bindings
MBS Matrix II trucks
9" MBS Tires
MBS 5 Star hubs
10/62 #25h chain drive
140kv Flipsky 6374 Battle hardened
Stormcore 100D
Hoyt Puck, Ice w/nub
Metr Pro
18s Graphene Lipo (12A)
Shredlights SL-200s
Range: Aprox 20-24miles
https://www.instagram.com/p/CLDUrDph88x/
Other than the ground does it matter which order the other wires go?
What do you mean? They have to be in the specific order B0-B10. They are not like phase wires and they have to go in order.
Basically this:
Ah OK that makes sense
Just followed you nice ride
I dont think vesc 4 handle 12s unless you get a unity/xenith.
What would be some good recommendations for VESC/ESC’s I can look at?
hard to beat this tbh. Its arguably the most tested esk8 esc ever produced. They should have stock soon
It’s only able to push 80 motor amps? Per side or total?
