Hey guys! I’m thinking about going lipo but am stuck on what to get. I’m looking for decent range with lots of power for max torque. I mainly ride in town but sometimes take it to some pretty gnarly hills. My current setup is:
Motor: 6374, 190kv
Tires: 200mm pneumatic
Gearing: 15t motor, 72t wheel
@kevingraehl @b264 @ahrav @MoeStooge @DEEIF
These are just a few that I know who have used lipos they might help
Lipos don’t last very long for me.
Is it because how hard you ride or just bad luck?
So basically what i have.
Been using 2x 12Ah 6s lipos in series since 2019
I’m getting between 20-25km i think (or 28km? I’m really not sure right now).
10s4p 30q gives me less range and more sag.
I was looking at these after I was told 12c just wasn’t going to cut it.
how is your power? Do you get good amounts of torque?
For my needs yes. It’s been a few months since i last took them out so I don’t really remember how it was.
I do know that thes can push some amps.
This was a very steep hill
Nice
So for consumption I’m confused on the 16.7 Wh/km and the 70 Wh/km
16.7Wh/km is average, 70Wh/km was right at that moment.
Ah, ok it’s making sense now. when I put the 70 Wh/km into the calculator it was giving me like 4.7 miles or 7.6km of range
I used turnigy lipos in my first build, they performed well but puffed and lost range/life quickly. I got about 3/4 of a summer out of them.
How hard did you push them? what were the specs on them?
damn that’s rellly not good.
They were the blue Turnigy 5s 5000mAh packs, rated to around 20-30C. It was in a 10s2p config so 10Ah. Probably 120 total battery amps on the VESC configs. I got maybe 50 cycles but ran them down to ~3V/cell so that’s probably why…
What are y’alls thoughts on these? would I be better off with these or the ones I posted earlier?
I’d rather go with 2 large ones in series than have to deal with 4 or more in series and parallel. Everything gets more complicated with more batteries, from the number of connectors (ie. potential failure points) to wire spaghetti to charging (especially balancing).
I couldn’t agree with you more.
You can also make a harness for a BMS if you would like to charge that way too. That’s what I did with mine. Much more simple than taking them all apart to charge.
what about these hardcase ones?
either 2 or 3 packs in series, seem pretty alright?
