The Smörğasbord |trampa HS11|TB6|Kaly Drive|APS 6380 170kv| 12s5p QB26800
I am thinking this will be my first offical build log here.
Here is the plan
Kaly drive
MBS front truck
TB6 vescs
Trampa holly pro deck
TB AT hubs with 8" tires
DIY 12s5p QB26800 Battery (6800mah 20 amp cells)
Smart bms
3 piece enclosure
Top mounted vescs
Stay tuned! Here are some pics
Finished putting the battery together
  • smörgåsbord :face_with_monocle:
Lol couldn’t find the right g
how are you connecting the kaly drive to the TB hubs? is it the same bolt pattern?
Yes it is
how are you mating @torqueboards hubs onto 12mm axles? do their bearing seats fit skateboard (22mm outer diameter) or mountain-board (28mm od) bearings?
don’t the og kaly drives mate with @trampa pattern wheel hubs? if so are the tb at wheels somehow compatible because they have their bolts in the same place?
edit: i’m too slow @mutantbass beat me to it
Aha, so good question, the front wheels will have mbs hubs which are the same diameter as TB hubs. And for the drive wheels I will simply use a 10mm bearing in the TB hubs which have the same bolt pattern as kaly hubs and superstars
good stuff. straight cut or helicals?
Straight cut. This is a used kaly I acquired some months back
nice. I got the straight cut too. More pics of the enclosure please :slight_smile:
what length is the APS motor shaft?
Not sure, what length but, they have been cut to fit the drives
Three enclosures, will jump wires between them using some sort of netting. These are from TB they are the 6s double stack enclosures he has on sale for 20 bucks each
cool so for the rear/drive wheels will you use a 28x10 or a 22x10 bearing?
Will use a thicker gasket on one of them to make room for the bms
clever. inserts or going all the way through the deck?
I think I will have to go all the way through, not sure how inserts will seat in the carbon fiber deck…anyone have experience with this?
heres my build thread with inserts
couple more resources
22x10 I cant find any 28x10 let me know if you have a source for em
Right on! Il take a look at those threads
i paid $3 per (shipped first class) from access bearings via ebay
they dropped it into the mail the day i paid and it arrived a few days later.
