The little touches.
Does this cable sleeving come in other colors? Link?
The one I got only had this black and white. https://www.amazon.com/gp/aw/d/B07FWH17MD?psc=1&ref=ppx_pop_mob_b_asin_title
If you use cable sleeves before connecting everything, should be able to find more colors.
Did a range test today cause none of the online calcs were giving me the true answer for my 4wd setup.
Was mostly cruising so, ended up being about 39 miles of range. Had to walk the last two home lol.
TWO MILES of dragging a board? oh GODDDDd
The furthest I’ve had to go was 1.3
I was kicking and riding it manually hoping to regen some lol. Didn’t much.
@sugandese here ya go, hope you enjoy ![]()
I never did get to a write up of the electronics so, here’s some more photos:
Ahh been admiring this thing for a while, such a weapon of a build man. How are you finding the 4wd? Do you run equal power to each corner?
Thanks! 4wd is awesome, the torque difference is simply amazing, and all 4 being open gear it just screams. I don’t have a 2wd nearly capable of the same torque so it’s hard to compare in that regard. But I really like that I can run 4 small 6355s and still punch really hard.
Haven’t experimented with sending different amounts of power to each corner. I have wanted to try and experiment with going 2wd mid range (so set duty cycle to zero in the front) to see one) how much more range I gain, and two) how much I can regen by doing that. More of a curiosity kind of thing.
And for a 4wd board I’m still extremely pleased with the range I’m getting, that was unexpected. I don’t know exactly what it is about my setup.
I just got my reacher 55’s in the mail today, I was surprised how light they are.
Main reason Ive gone 4wd is for the sharp turns and braking in t-race. Have you experienced any understeer from the front wheels spinning out of tight corners? I’ll have 85’s at the back so will already have a power bias to the rear but Ive wondered about playing with throttle ramping or curves as well.
Have you done the t-race? Looks like the perfect board for it.
I’ve just been getting used to the board so don’t think I’ve pushed it hard enough yet to experience any under steer. I would definitely recommend in general to play with the throttle curve. I’ve definitely messed with mine to be punchy both ways. I also want to mess with those new values @Tony_Stark mentioned recently for FOC.
I’ll definitely try t-race, but I need to find a spot to do it, get a timer, and some cones.
Here’s some ear candy for y’all.
2wd boardnamics 5.5 straight cuts (my only board at the moment) vs 4x4 SRB open gear straight cuts
Just when I think I’ll be happy with my build for 5 minutes someone makes me realise I need to spend more money.
It’s the circle of esk8 life lol.
Wait what do you want now?
I’ll get the 3 links too eventually, just keen to see how well I can do on that leaderboard without them first.
Myself and some locals actually prefer the boardnamics straight cut sound on my raceboard, they really do sound nice
If I was going to be commuting on a board, I would probably choose the BN straight cut noise level over the SRB open gears. They are loud enough that people know you are coming but not loud enough to annoy me with a full face on.
That being said, the aggressive growl of the SRB gears puts a big smile on my face every time I hit the throttle.
@sugandese the new RS tires are superb. I think the Meepos look beefier and have a wider contact patch so, when installing I was like hmm kind of prefer the old look with Meepos…
But when I rode, man there’s a world of difference. First they’re not as comfortable and ride harsher, but not a deal breaker for me. They almossst roll like thane, closest you can get? And my board is already stiff so I’m already feeling all the bumps.
At speed is where the biggest difference comes in. The Meepos are not bad in terms of balance, but today I confirmed the tires would cause vibrations at high speeds. I used to think it was just my clothes or something flapping in the wind. So I always felt uneasy pushing any further. Today I felt way more comfortable and there were no vibrations. The RS tire claim to be speed rated up to 50/80 mph/kph, and come with instructions on how to further balance so maybe that’s why.
Other notes, the Meepos don’t seem to be truly 165 mm. Both claim to be 165mm, but Meepo is obviously a bit larger. I measured the RS they do seem to be 165 as they claim. Anyone else ever actually measure the Meepos?
Also found it interesting you have to go up to 60psi first then back it down to 30-32 recommended psi for flat profile. Here is the tire when first hitting just 30psi:
@Sk8tedad if you don’t mind the price and can get a hold of these, I really think you should try them out, I also have some TomiBoi hubs you can throw them on.
