THE New Go-FOC DV4s
@Takachi14 be like, who needs train when u r the train :rofl:
No heat sink, all the amps and 8" rubber. VESC is only getting warm to the touch.
Probably not as scientific of an answer as you were looking for, but there you go.
No surprise, I’ve always been enamored by smaller profile boards that can cruise and are mostly urban than AT. In fact its my next goal to build something that fits that bill. Once I get my original two boards back together. That said I’ve never been a fan of thanes’ so gotta look around for some smaller penus’ than the typical mountain board affair.
https://www.hoytskate.com/products/hoyt-st-5-tires-tubes-and-rims
Was already going to order a Puck today to replace my vx2. Might as well start piecing together the build now :smiley: Much appreciated.
Edit: Again apologies for the slight(?) derails here. Will knock it off :smiley:
I’m not using heatsink, but I’m also not using telemetry. I’ve been hitting hills that are pretty steep for extended periods, riding around a mountain coast roads. 140kv, 2.78 Nd 105mm wheels. Haven’t had any indication of heat being an issue. Ambient outside these days here is like 25-30 degrees, goes as high as 38 at peak sun.
Word is there will be nylon 5" rims with kegal compatibility coming Thoonā„¢.
That opens up some GD options. ATM, the cnc ones are only belt compatible
For those wondering how I solved the motor cut out under load issue.
Entirely my fault. Apparently vesc can’t auto detect which hall sensors belong to which coil. I had the connectors mixed up.
What
chuga chuga chuga zoom zoom
Yeah, nah. I won’t attempt to beat a train that goes for 120kph.
I just need to get to the station more efficiently than walking/driving/taking the bus*.
*bikes get stolen and are too big for the rush hour train.
Anyone know if I can set my dv4 to only turn on using push to start and set it to turn off after 5 min of no input
Set the shutdown mode to OFF_AFTER_5M on APP page.
Note :
DV4 does not support switch, but on DV4s.
New issues guys and gals. When going full throttle the motors cut out / stop and don’t re engage until I go to 0% throttle. Video for example.
Is the shutdown mode set correctly? The left side needs to be set to Always ON
yes
Another video of noises coming from the motors when running
No faults being thrown?
None. That being said when the motors were stopping at 100% throttle no faults were thrown either. To check faults I’ve been going to the dev tools tab-> vesc terminal then typing ā€œfaultsā€.
What is your duty cycle current limit start set to?
