Features:
*Building based on VESC
*All aluminum alloy heat dissipation shell
*Built-in switch (supports pushing to start)
*Small volume (96x60x19.5mm)
*100A phase current on each side
*More mature circuit design
*More reliable stability
*Custom Firmware
Warning:
Left side shutdown mode needs to be set to ALWAYS ON, otherwise the left side ESC will stop working!
DV4s prototype and DV6pro
Dang so cool! May I know the hole pattern on the heatsink so I can support it in my ESC enclosure?
@YUTW123 do you need to buy a separate blue tooth module?
YES , No built-in Bluetooth module
Thank you, I appreciate it
May I also know the depth of the holes?
Evwan
May 4, 2023, 4:09pm
#8
I dont even really build 12s boards anymore but i’m buying one
frame
May 4, 2023, 4:51pm
#11
whats the dimension of this dv4s?
I mean 100 bux, da price is right!
frame
May 4, 2023, 4:58pm
#15
thanks, im dum
this is smaller than a unity, sheeesh
Evwan
May 4, 2023, 5:00pm
#16
Stormcore 60D+ 126x70x23
DV4s 96x60x20
old DV4 92x77x23
Just bought one, this is a great offer
If this fits in a Meepo V3 ESC enclosure I’m gonna be so happy
Cant you change it to a somewhat standard pattern like the dv6 or unity/stormcore? Would help with heatsink compatibility
