ok here goes after a lot of research, my chepo diy build of anti spark switch a bear bones design, no pcb!
looking for about 100amps ish, with a fuse. going to base it on vedder design seem to work ok.
3 mosphets IRFS7530-7PPBF N-Channel MOSFET, 240 A.
4.53 pounds.
This is definitely bare bones dude. You’ve literally just mentioned the words antispark.
from what i read, loop switches work quite well
Loopkey is really the only 100% reliable method.
Every antispark switch i’ve read of has had issues.
eventually one will come that works im sure
So go forth young man, and forge the way to a new era
Nothing is perfect
100% is a strong claim
Heres a question:
Does anybody know the internal workings of the xt90s ? Like how does it suppress the spark?
are you diode connecting these fets?
whats your schematic>
going to use this one
Change r2 to be 100k and add a termination resistor.
what a 10k across the zenner?
Yes. These two posts shed some light on that. Ask in the loopkey thread if you want more info ![]()
or does design work better?
sorry this one
https://drive.wps.com/d/ABtXKk707MEc45aMvIqdFA
[File]Antispark Rev3 (1) - Copy.pdf
ummmmmmmm i dont have access to your pc
From what I understand the inrush to charge the capsitors on the VESC is what blows the anti spark and if I rember right there was a post saying that was over 1kA. Could you not just double up the mosfets to make it more reliable? Put 3 more on the back or some thing? I may be completely wrong and that wouldent work for some electronics reason.
You use an RC timing circuit to limit in rush current.
Or an expensive power resistor precharge network…
You could potentially just stack fets intil it works.
the real problem is the lack of precharge circuitry
Flipsky tried to stack 10 MOSFETs glued to a heatsink and it still failed.
