Thanks.
Are there any other models available?
Daly can pretty much make you whatever BMS you want, as long as you’re willing to pay (and accept an absurdly large size, in some cases)
why does the 12S one just have to come in literally a larger size than 13S can
You can use the 13s Daly for 12s. 12th pgroup will balance twice as fast, which doesn’t really matter.
Ugh I know. I have asked Daly about this several times and never got a satisfying answer.
I even brought this up. I was like “can you just make me a 13s BMS with the last two pins shorted internally, and populate a 12s header?” Nope, no dice.
Pretty frustrating.
can I use a 24s bms on a 12s battery for lightspeed balancing
@Trampa this one of the problem packs?
That would be my guess, yes. What was the identified problem again?
metal bolts inside of the battery enclosure. The kinda thing we would have called out if it was posted in this thread.
Fire, it seems. I’m pretty sure the presence of persistent flames caused some damage to the assemblies of the contraption.
He wasn’t carrying the correct equipment to deal with situations like this.
by the size for a second I thought they were 4680s but then I read the top right
Who the hell even uses C cells for anything anymore? I haven’t seen, used or thought about those in literally years lol
Seniors use them for their old filament bulb flashlights or their portable FM radios around here
Absolutely. Last week i told my granny to throw away her flashlight that needs 2!!! C cells which is still worse than a tiny modern flashlight.
Lol they heavy and probably like 40.5 lumens
Pfft, if that. Given the efficiency of filament bulbs, I’d guess lower.
