Is it safe to discharge a cell a 5 amps? I am using a hobby charger to bring the cells to the same voltage as the rest of the pack to rebuild the P-group
Hello guys, I am now working on the second version of my battery module system. I was wandering if there would be any 12S bms that is charge only, no balance connection. This is because I was planning to balance the packs individually (4S packs) and have a bms for the charge/discharge that handles the whole 12S series connection.
I always re-weld any spots that look less than optimal. I usually reverse the polarity while doing it (swap the red and black probe position) because I find that I typically get a slightly stronger weld on one or the other.
The biggest thing for me was my power connections…
@Tamatoa I mention mounting the welder to the battery in my video, and I think you’ll find the welding order pattern very helpful.
Also, as for discharging to get the voltage in line with other cells, you’ll likely find more bounce back at 5 amps than you would at a slower rate. It’ll work perfectly fine, but chances are you’ll have to add the load back to the cell when when to voltage creeps back up. If you’re going for precision at all, I’d put a load of an amp or less on it and get it done in one go.
