Ugh how rudimentary. Those still exist?
Lmao it is cheaper and better for printing a flat pattern
Yes of course
I donāt have one at my apartment though so Iām not sure what Iāll do yet
maybe if you check an antique shop
Youāre weird lol printers arenāt old
Foreshadowing. Just for jokes
Haha yeah I know about these I considered it
I want to get some but Iām afraid my battery wires will desolder if I push it any harder
I worry about that too lol
Hello, I finished my battery but I wanted to see if anyone could check my wiring. I understand how the balance wires and B- connect and I am discharging through the BMS (60A). I want to be able to charge the battery without my loop key plugged in. Also my LTT BMS came with a positive and negative connection (picture below) that was plugged in next to the bluetooth port. I assume itās for an on/off switch, but since I am using a loop key, will it work if I take it out?
Thank you I appreciate any feedback!
Usually a pc case is grounded, if not the power supply surely is.
If your super cautios about static its easier to remove materials that like to make it and a lot safer than for example to ground youself to a socket and then work with some faulty equipments and kill yourself
I havent had that problem and I push mine really hard. Itās not like you are unaware of how hot the cables are getting. It just means that your fingers dont burn haha.
Iām still just using a single graphene lipo, and the 5ish cm of 10AWG wires on battery leads get too hot to touch⦠The battery itself gets warm but nothing like the wires. I figure when the probes get too hot to hold then its probably good to give the wires a break too.
I think on the Kweld facebook somebody had the wires in their lipo desolder when they pushed it too hard, thatās what got me worried.
Anyways Iāll probably be using two in parallel soon so that wonāt be a problem.
What if I donāt have a pc? Will any of those work?
Do you have metal plumbing? I believe it should be grounded.
Hello Guys! I hope you can help me in this topic. I ordered a 12s6p 18500 battery. Its arrived around 85% charged. I didnāt charged and i used it until its drowned to 5% around, then i charged it fully. Yesterday i used it for 8 kms, then i accelarate on full trottle, it shutdowned when i reached 25km/h (approx). It was close to fall, so i feel dangerous now. I coudnāt switch on. I started to charge it, then i can switch on again. I will test today that is it shutdown again. I thought it has cell faliure, but im not sure. What can be the reason of the immidiately shutdown of the battery? Can be settings in vesc? Or the battery is faulty? Thanks for help!
To answer your question, you need to disclose the VESCās Battery current max setting and the maximum amperage of the battery pack. If possible, also the specs of the cells you are using in the battery pack.
So i think my batteryās max amper is 120A. in vesc settings it is 30A/vesc (4 vescs). Should set lower?
