ah ok cant remeber who it was that told that to me
sorry will correct my post
I have to confess every time I wanted a fuse for the charging circuit I went on amazon and only found these ones and ended up not fusing it at all
Very interested on what you guys use specifically.
I use âefusesâ, electronic fuses that use MOSFETs to switch the current on/off much faster and more precisely (at very particular current levels and timing). Iâm sure others will chime in with their recommendations for standard fuses though.
ah nice and can you just reset those when they blow?
Check Digi-Key, Newark, Allied Elec, and other dedicated component suppliers. Amazon is not the place to shop for these. ![]()
SelectableâŚyou can button reset or they will automatically reset.
how large are they? can you link
They are a chip you have to design a circuit around. Multiple manufacturers make them but I use ones from TI: https://www.ti.com/power-management/power-switches/efuse-hotswap-controllers/overview.html
Much bigger and more expensive than just a regular fuse though. But you get a lot more control and functionality for the size and cost.
A polyfuse might also be an option.
(Is used for lower voltage and current mostly)
OohhhhâŚwaitâŚI goofed. You have a 12S pack at high amps. I donât think they have an efuse that will work for you. Check the hot swap controllers.
I use the efuses mostly for lower voltage or lower current levels.
Check Analog Devices too: https://www.analog.com/en/parametricsearch/11394#/
The LTC4368 is the type of chip that can protect a 12S pack.
No you didnât, only interested for charging, so a limit around 10 to 15A.
I was just looking into that earlier today. The 60V ones I found topped out at 5A. ![]()
Yup! This isnât the neatest work but you can see no cross overs (there are but itâs in free space so they will not rub under pressure)
