Ehh, still no need. I use a 2a on the 7p most of the time, 8a only comes out if the lady said we are skating that night
Thatâs the one Lacroix uses.
15A!? thatâs cheap isnt it? Iâve not bought one that high an output, only 8A lol, but generally is seems the prices increase about +$10 for every amp.
Ehh, diminishing cost per amp, my 2a is $20 and 8a is $60 so 15a at $75 seems reasonable
Yeah I wouldnât expect it to be $150 but my 8A was $80.
I wonder if the fan on a 15A charger sounds like a jet engine lol.
Great TIL.
20a
Thats super cheap. I paid nearly 250AUD for my 20a brick charger
(Meant as a reply to @Dinnye)
Worst case you can get Eboostedâs enclosure for it, which has a width of around 188mm inside.
My plan as well. Great minds think alike
This is so clear and helpful, thank you. I havenât quite got my head around how a double-stack would work though - I dont suppose youâve got a similar PDF but for double-stack and then I could join the dots between these 2 diagrams?
It depends if you are doublestacking for 2x capacity or doublestacking for space management.
Alright, if DIYing the enclosure doesnât work out as well as I expect it I will buy the eboosted one. I thought his enclosure was a bit narrower. Good to know! I will try to DIY the enclosure tho, since eboosted doesnât sell them for cheap, plus shipping to EU and paying VAT are also quite expensive.
Btw my reasoning for the ESCs on the tail is that I will need heatsinking when I upgrade my motors as well, so I would rather do it right the first time. Glad I am not the only one who wants them on the tail, the more people do it, the less stupid it looks xD (at least on a street setup)
I was really thinking about changing up my trampa a bit.
I get an EBoosted Trampa enclosure and put a 12s4p P42A in there, and take off the top mount enclosure. Then figure out a quick attach/detach mounting solution for the top mount.
So for quick rides I can just use the board regularly, with 16.8 Ah of battery, then if I need it I can pop on the 27 Ah top mount box and get 44.8 Ah total.
Plus there would be a ton of weight savings in the low range mode. But I am worried about scraping things on the bottom of the enclosureâŚ
I am tempted to get one of these rd6012 for up to 14s charger and 12amp. $150 including a case and power supply. Currently use one their 50v 5amp buckboost to charge the scooter after the power supply died.
Get one of those and you for a lab power supply as well!
On my shopping list for next week. Should have bought one a long time ago.
So Iâm pretty much doing the same thing youâre doing. P42A 12s4p 16.8Ah at 3.2kg
Or
30Q 12s5p 15Ah at 2.8kg
30Q 12s6p 18Ah at 3.4kg
for space management - just so the 12s4p will fit in the limited enclosure space.
