Ideally I’d put the two series connections at equal distances on the nickel pads, so the load moving through them is more easily distributed.
More than likely not an issue. For those amps, I suspect it will be fine
it’s it looks like a grid of 0.8mm-10mm wide segments? not 25mm solid across? am I seeing that right? how wide are the segments.
hope you don’t mind me thinking through this.
I see either this naively Path A:
but I suspect it’s more complex like this Path B:
so I think that means those segments need to be 12mm wide to be “acceptable”
thoughts? is my thinking off?
those numbers assume 15 amps per cell ofc.
it is not solid no it is a nickel belt. however i think you are over thinking it. electricity is going to take the path of least resistance yes. however since the amount of distance electrons will have to travel through the nickel is so short, the heat that is created will dicipate into that 14 awg wire. i feel like this particular 10s3p is overbuilt as it is. real world of course will show. you have to keep in mind those pieces of nickel are all at the same electrical potential, as soon as one spot heats up too much resistance will be increased and electron flow will simply take the next path of least resistance, or any piece of that nickel that is cooler on so on and so forth. so realistically, since there are 3 pieces of 8mm wide nickel connected to the 14 awg wire its as if it was one piece of 24mm x .15 but honestly because the piece of nickel is short, for this 45 amp battery i would be comfortable with just one piece of 8mm x .15. any heat created in that short piece of nickel would be distributed into the braid/wire very quickly. However since nickel belt is very easy to work with i cut it so that each cell has an 8mm nickel path to discharge through.
could it be built better? yes. overkill is a thing
you can see why trying to plan p42a packs is breaking my brain.
tell me a bit about that pack you are thinking of building
12s2p in a tayto. 12s5p in a prototipo.
so far I’m thinking of simple flat pgroups with a sheet of 0.2mm x 25mm nickel folded over, to multiple series points / coper wires to the next p group. I was trying to get myself to draw it out at some point and post both layout and series positions in here.
beyond that I haven’t figured everything out.
i think that is a good plan
Aren’t 30q underrated at 15A and most consider them 20A?
Yes but, factory rating is 15amps. Some people put 30amps on 30qs. But I don’t ever recomend pulling more then 60amps from any 3p pack. That’s alot of heat.
30q will comfortably operate at 20a, but its likely not great for their longevity
I’m making the same pack, same layout slightly different linkage. Waiting for a new spot pen to come in to finish it.
That looks great! I think that is deffinelty a better series connection then what I did. However the pack I built is for a HAYA integrated deck, didnt think I had the space for that sort of constructions. The cutouts in that deck are fairly small. Also the double 14awg, is pretty overkill, but I like it!
Overkill is me using 25x0.2 nickel and 1/2" tinned copper braid for a 3p 30Q pack because that’s all I have
Does anyone have 1/4" braid?
Looooool! I like it
Nice! Yeah 40t a bit more discharge for sure,
She’s gonna be pretty
It’s for @Crispeasy’s Halo Board
All of the labels are the same direction…does that make me professional yet?
so did you solder wires to nickel before welding on all of the series connections?
