i just have some cloth tape on the side of that pack, this particular pack is going into a HAYA, so there is no need for anything as it has that long plank down the middle
you got a link for that clear shtinkwrap?
What about for a pack without the wood divider? What do you normally use?
There isnât any clear shrinkwrap on any of these packs
but if someone had a link to that size clear shrinkwrap, Iâd build all my packs with that stuff
Thanks a lot for the info
@Skyart uses clear shrinkwrap every so often, thatâs why I asked
@iamasalmon I learned from the best
You think nickel suppliers are closely guardedâŚclear shrink wrap is top secret level classified.
give me your nickel.
Hehe I got a small stash to show of my pretty parallel groups
i definitely get mine on amazon lol 250mm and 300mm clear shrink wrap
Anyone have a good supplier for 25-50mm 0.2-0.3 nickel in the US?
No, but if you find one let us know!!!
@Skyart what was your thinking of this observation?
45a continues battery, that connection is more then able to carry that kind of current.
nice.
is it 10s4p 30q? is that 2 layers of 0.15mm x 8mm nickel? I wanna think it through for practice.
10s3p 30q, one layer of 25mm by .15 nickel belt
At the upper arrow, where the wire intersects just above the middle (of 3 bent over the edge) connection.
So theoretically the connection at the upper wire is seeing the full amperage of both of those cells. 30 amps, or 40 possibly for 30q. Looks about 10mm wide there
Whatâs the series connection? 2x14?
yes series connection is 2x14
