I measured one on either side and the middle for you. I also tested another cell trying to charge it with the IMAXB6, same thing counts 3 mah then jumps to full.
I’m thinking next I might take all the cells to the storage voltage with the Imaxb6 (it seems to work fine with them for discharging) which would take like 2 days of non-stop work thank god it’s raining or I would give up. Then I would try with the BMS again and see if it still stops at 48v.
when I charge with the BMS or the Imaxb6? I doesn’t seem to be a fault in the cell itself or the connection due to the issue being identical with multiple/all the cells.
like you want to see if the cell is reading 4.2v like the imaxb6 says it is?
I know the BMS is shutting off for whatever reason and not doing anything.
I can really get to the cell terminals but I noticed when charging with my bench power supply that the balance leads give me the cell voltage so I’ll try it.
This time it decided to charge… UGH wth
tried the bms again still shuts off then turns green the moment I turn on the BMS
this is hard because the jst connectors are in the BMS then. I would think when the BMS get getting near the end it needs the full input voltage it is expecting to have in order to function, but I know you are supposed to be able to use a bms with a lower charge voltage than intended and it should work.
I’m getting really good at walking the probes along the jst connector
I still think I should try to give the BMS the proper voltage and see if that works. Any ideas on how to read the cell voltages while the jst connector is in the BMS would be good. Getting to the actual cell terminals is tough but I could tear the sides off my shoeboxpaper based battery case to get to them.
Children’s scissors to the rescue!
Turns out no loose screw, it probably would have already blown up if that was the case. Looked like a screw due to the threads showing.
Not seeing any pots to turn on here.
It appears the plastic post broke because the PCB doesn’t fit into where it’s supposed to. The holes would line up but the wall that holds the fan is in the way…
Had me thinking what about a 12S3P battery in there and a vesc… I’ve got a set of meepo hubs I could try with 12S. Dunno how they would handle at that speed tho.
I hope I’m Posting this in the right place, but I’m trying to fit 21700 cells, 12s5p config on a vanguard flex 3. I have some of my kids blocks to simulation how it may fit. It’s a 8s5p front, 4s5p rear along with a Y connector at the VESC. The red blocks simulate the VESC. Please advise on experience splitting the battery packs. Thanks First Build.
