A bit more tidying up and will be done.
Main battery negative and b1 are different?
So does that mean the eleventh wire on a 10s battery goes to main battery possitive?
You only have 11 pins. That is one pin for each cell positive and one for main negative.
Correct
Ahhh I see
Well yeah. B1 is first negative (often common rail as main B-), B2 is second point, all the way to B11 which is last positive position?
Yeah. It fucks with me how they start from 0. B- should be B0, group 1 B1 etc… but they just have to make it confusing
Anyway, thats only a problem if you follow the diagram. Diagrams are for wussies. Just plug shit in and see what happens
Who start from 0?
This is not good advice BTW anybody else reading ![]()
The only diagram I ever followed was a diebiems diagram. Pretty sure it started from 0
I mean technically since electricity flows from negative to positive, it should be 0, -1, -2…
I see, ok so I need to do a little swap on one wire, no big!
The point is, Stick a volt meter at the very first negative pin and probe each sequential pin. Every pin should add 1 cell voltage. Every pin from negative goes up until last pin which should now measure full batt voltage.
Should not need to say don’t let your probes touch. Or you’re gonna be re-doing that connector again.
This makes sence!
shrink wrap on probes is a good idea. I want one with the retractable probers
Meh. I prefer to play on the wild side. Just 2 standard probes on 2mm pins. It’s just like the game of operation everyone played as a kid, except buzzer is more like a bang and there is more consequence. But what is life on the boring road, live a little.
I just tried to charge my spim08hp pack but my BMS stopped because the cells are unbalanced by .2V so I need to manually get the rest up. I was relieved to find out my BMS is fully functional given my rapid uncoordinated construction methods.
12s D140 can be used on a 10s battery right?
Just not connecting the last 2 wires
Nah, voltage cut is going to be all wrong for charge. And I think it wouldn’t even charge, it will think there is 2 dead groups and open the charge fets.
