That would pass my QC. Good saturation, not excessive solder, wires pressed together, 9/10.
That is really not a nice thing to say for all the Enertion technicians out there.
Thanks for your honest review.
anyone been getting this ad?
what do you think about the message?
this motherfucker paid $18.99 for a VTC6 on Ebay no wonder he blew it up
Well they are completely right imo
But they projected the message in a shit way with that video
I only say cases for bare cells to minimize the risk of shorts.
yup easy and cheap
Right in the video they’re going after the average battery consumer, but I think the problem they’re trying to address is devices being sold like a lot of vaporizers with removable lithium-ion cells.
Good morning guys. I am thinking of switching from lipo to li-ion. I need advices on building a 10s3p battery pack. I built 2 lipo 10s packs b4 so know a little bit about the danger is building a battery.
My plan is build my pack with Samsung r25 18650 cells. 7500mah and 60amp is enough for my use. Before starting I have a few questions and would like ppl here to give me some advice.
18650battery story has Samsung r25 for $2.99 each is that a good deal?
I know spot welding 18650 is best but I don’t have a spot welder and I know soldering would damage the cell. What other options do I have besides spot welding.
Thanks you.
You can buy 18650s from some places with tabs already welded to them and then you can solder to the tabs
A lot of guys here like to use the NESE system as well. I’ve never used it but I think it’s a great idea. More info here - NESE, the no solder 18650 battery system
Burned out 5 of them
Got sick of them failing and went for a weller one
Especially since I cant find them locally
Well my first did hold up one year till the tip was done. Never had one fail and for 8$
I don’t mind to buy one new every year.
But others who bought some in similar price range with plastic grip didn’t have had so much luck. So there is that.
With a weller you never go wrong if you have the money to spend.
Animal.
25R is a 15A cell (you can check via google). 30Q is a 20A cell and a great upgrade in every way, even price.
You just made me realize that all the complicated solder jobs I’ve done with thick wires where I’ve tried meshing the wire strands together or wrapping them around one another were pointless because this is just as good as long as you have enough solder
If you use too much, is hanging there like raindrop. That solder job was a 10 awg wire to 12 awg for a bms.
Their voltage sag is huge
There is often a gap between manufacturer supplied specifications and real world use. 25R and 30Q are very popular cells, and the internet has much practical data.
Wrapping them makes them so much easier to solder tho… i don’t know what kind of voodoo magic @Mainflow used here to keep them all so neatly together while he soldered
Also, wherever possible, solder should be used as an electrical connection only, not mechanical. If that joint heated up enough, it could easily come unstuck
Wire wrapping is a good practice imo.
It was only supposed as a electrical connection, not mechanically.
(That job was for the new baja bms)
Basically I learned soldering in 10 minutes a few years ago
So how is it mechanically connected?
